Upgrade your motocross setup with one of the best lap timers in the industry — the Solo 2 DL motocross GPS lap timer. Display instant speed, timing splits, live data and delta lap times on a high-contrast display with an accuracy of up to two-hundredths of a second.
Why Choose the MX Track Day Solo 2 DL 
Building on the features of the Aim Solo 2 model, the Solo 2 DL MX lap timer connects directly to your bike’s ECU to record vital engine data, without the need for complex wiring. Compatible with a wide range of motorsport applications and bike ECUs, the Solo 2 DL is a versatile tool for helping motorsport professionals monitor and improve their performance in any motorsport discipline.
Solo 2 lap timer on motocross bike
On-Screen Delta Feedback
The Solo 2 DL motocross lap timer has a sharp, high-contrast display which helps riders easily identify the data displayed on screen, as well as 8 different backlight colours.
Thousands of pre-loaded worldwide track maps are available, the MX lap timer automatically recognises your position on the track as soon as it's switched on. Once you start to ride, it automatically recognises the start line coordinates of the track and starts sampling lap times every time you go past.
Whether it's used for motocross, supercross, or enduro, the Solo 2 DL allows you to create a new temporary or permanent track layout too. Even if there is no track already, the device will create one for you.
Inertial Platform
Mounting Options
To take your data one step further, the Aim Solo 2 DL motocross lap timer seamlessly connects to Aim SmartyCams and a variety of MX sensors to increase your data performance and enhance your analysis with the added visuals and overlays, as well as additional sensor information.
  • Display: Graphical LCD
Integrated Track Database
  • Over 4,000 worldwide
  • Wi-Fi Connection: Yes
  • GPS: 25Hz
  • External Power: 9-15V
  • Memory: 4GB
Solo 2 DL pinout
  • Solo 2 DL front view
    Solo 2 DL
  • Cable icon
    Your Chosen Connection Cable
  • Cable icon
    Power Cable with AC Adapter
Solo 2 DL User Guide
Solo 2 DL Tech Sheet
Videos
Overview
Charger la vidéo: An in-depth review of the main features and functions of the Aim Solo 2 DL motocross lap timer.
Aim Solo 2 DL
Aim Solo 2
  • 4GB Internal Memory
  • Automatic Track Recognition
  • Integrated GPS
  • Ten Configurable RGB LEDs
  • Wi-fi Connectability
  • GLONASS Receiver
  • Direct ECU Data Logging
  • Predictive Lap Timing
  • Choice of Connection
  • Integrated GPS
  • Graphical Display
  • Solo 2 DL
  • Choice of connection Cable
  • Solo 2
  • GPS: 25Hz
  • Memory: 4GB
  • GPS: 25Hz
  • Memory: 4GB
