Peak Traction Power & Endurance
Engineered by Super B Energy, the Epsilon Battery delivers reliable lithium power with advanced safety, monitoring and thermal performance, making it a go-to choice for motorsport teams and mobile adventurers alike. The Super B Epsilon 12V150Ah Lithium Iron Phosphate Battery offers some of the highest power capacity currently available in a standard-size casing.
Specifically designed for electric vehicles, hybrid vehicles and other electric industrial equipment, these batteries provide superior performance thanks to their integrated battery management system (BMS), automatic heating functionality, Bluetooth monitoring and environmental benefits.
Super B Epsilon 12V150Ah Intended Use
The Super B Epsilon 12V150Ah Lithium Traction Battery powers a range of 12V systems, and measures in at 353 x 175 x 190mm and weighs 15.5kg. Its high discharge current and superior voltage stability under load make it ideal for motorsport teams who demand consistent power output under stress.
Beyond motorsports, this battery shines in recreational vehicles, commercial vehicles, leisure boats, commercial vessels and stationary applications where space, weight and reliability are crucial. It can be used for off-grid power supply, marine power supply or a medium for (renewable) energy storage, and its compact size and fast charging make it the perfect drop-in upgrade from bulky AGM or lead-acid systems.
Please Note: Use as a starter battery is not possible. Never install multiple Epsilon Li-ion batteries in series. Up to 8 batteries can be connected in parallel to increase the total capacity up to 1200Ah for the 12V150Ah Epsilon variant.
Why Choose the Super B Epsilon 12V150Ah Battery
Super B Energy Batteries are leaders in advanced lithium battery technology, with a focus on high-performance, long-lasting energy solutions for mobile and off-grid systems. The Super B Epsilon 12V150Ah Lithium Traction Battery reflects this legacy—engineered for endurance, designed for professionals and trusted by champions.
The Super B Epsilon is a Lithium Iron Phosphate (LiFePO4) battery, providing 5,000+ cycle lifespan, integrated BMS, Bluetooth, and automatic heating for cold-weather charging. It is a high-capacity drop-in replacement for various applications due to fast charging, high energy efficiency, and rugged design.
Integrated BMS
The Super B Epsilon 12V150Ah Battery incorporates a battery management system (BMS) to ensure a high level of safety during use. The BMS regulates temperature, voltage and current to protect your system in real time against overcharging, overheating, short-circuiting and imbalance, while the multi-connectable coated aluminium terminals and a robust housing make installation flexible and secure. The integrated BMS also provides cell balancing.
Safe & Reliable
Due to its LiFePO4 prismatic cell technology, which is renowned for its exceptional safety, long cycle life, high energy density and integrated BMS system, the Super B Epsilon Battery is amongst the safest lithium technologies on the market. As well as the technology, the Epsilon Batteries' robust casing is made from environmentally friendly (fully recyclable) PC-ABS with an ingress protection rating of IP56. These features make the battery resistant to water and dust, which is ideal for extreme motorsport and off-grid systems.
High-Performance
Compared to traditional batteries, the Super B Epsilon 12V150Ah Lithium Traction Battery delivers faster charging times, a significantly longer lifespan and more usable energy per cycle. With over 5,000 cycles at full depth of discharge and over 96% energy efficiency, it's an investment in long-term performance and peace of mind.
Its low self-discharge (less than 3% per month) ensures that the battery retains its charge, even when not in use—ideal for seasonal applications like racing, sailing or overlanding.
3-Year Warranty
The Super B Epsilon 12V150Ah Lithium Traction Battery comes with a 3-year manufacturer warranty and support from Aim Shop’s experienced technical team for your peace of mind. Whether you're building a custom energy setup or upgrading your race vehicle's power system, Super B provides batteries that have been engineered and tested against the harshest of environments to ensure high-performance for years to come.
Testimonials
Trusted by racing teams, adventurers and sailors worldwide, Super B Energy Batteries are renowned for their reliability, compact size and seamless integration with modern systems. Take a look at some of the testimonials from people who have used Super B for their own projects.
Feel The Breeze SuperB Epsilon Testimonial for sailboat
Feel The Breeze
"We have 8 lithium iron phosphate batteries (LiFePO4) at the core of our sailing yacht, a massive upgrade from the old lead-acid. The simplicity of installation, quality, and durability made this a no-brainer!" - Feel The Breeze
Stepsover World Tour Super B Testimonial for 4x4 MAN truck
"Lithium batteries are the best solution for an overland truck like ours. Our truck is equipped with a useful domotic system that controls everything inside the truck, from the ventilation system all the way to the water pressure inside the plumbing system. This is really useful in order to prevent damage on the road and to manage every function of the interior with just a click on our tablet. We successfully integrated the new Super B lithium batteries in our truck and now we really feel more independent." - Stepsover World Tour
Sailing Fair Isle Super B Epsilon Testimonial for sailboat
Sailing Fair Isle
"These batteries are a game-changer for living off grid, and we know, from talking to our fellow cruisers, that we are not the only ones making this change to lithium. Super B are the best in the business. As we continue our journey around the world, we feel safe in the knowledge that these may be the last set of batteries we ever need to install." - Sailing Fair Isle
  • Configurable general-purpose inputs/outputs to control external devices like chargers.
  • Multi-connectable coated aluminium terminals, including temperature sensors for protection.
  • Integrated and configurable discharge limit (Shutdown based on State of Charge).
  • Separate power output connection for powering accessories. Analogue SoC output.
  • CAN bus (wired), LIN bus (wired) and Bluetooth (wireless) connectivity allows you to monitor your battery in real time using the free Be In Charge app.
Electrical Specifications
  • Nominal Capacity: 150Ah
  • Energy: 1920Wh
  • Nominal Voltage: 12.8V
  • Open Circuit Voltage: 13.2V
  • Cycle Life: >5000 (0.3C charge/discharge, 100% DoD), >3500 (0.9C charge/discharge, 100% DoD)
Mechanical Specifications
  • Dimensions (LxWxH): 353 x 175 x 190mm / 13.9” x 6.9” x 7.5” (=DIN H8 / LN5)
  • Weight: 15.5kg / 34.2lbs
  • Case Material: PC - ABS
  • Ingress Protection: IP56
  • Cell Type / Chemistry: Prismatic - LiFePO4
  • Battery Designation: IFpP/27/148/135[3p4s] M/-20+60/95
  • Charge Method: CCCV
  • Recommended Charge Voltage: 14.4V
  • Max Charge Current: 135A
  • Discharge Current Continuous: Max. 200A
  • Discharge Pulse Current (10 sec): 350A
  • Short Circuit Detection: 1550A > 70 us or 610A > 8 ms
Temperature Specifications
  • Charge Temperature (heating off): 0°C to 45°C / 32°F to 113°F
  • Charge Temperature (heating on): -30°C to 45°C / -22°F to 113°F
  • Discharge Temperature: -20°C to 60°C / -4°F to 140°F
  • Storage Temperature Short Term (<1 month): -20°C to 45°C / -4°F to 113°F
  • Storage Temperature Long Term (>1 month): 18°C to 28°C / 64°F to 82°F
  • Relative Humidity: 10-90%
Compliance Specifications
  • Certifications: CE, FCC, UN 38.3, UN ECE R10.06, UL 1642 (Cells)
  • Bluetooth Certification: Declaration ID: D061640
SKU: SB-E-150
Super B Epsilon User Guide
Super B Epsilon Quick Start Guide
Super B Epsilon 12V150Ah Tech Sheet
Epsilon 12V150Ah CAD File
Epsilon 12V150Ah Safety Data Sheet
Super B Energy Charging Manual
How do you download the "Be In Charge" software & app?
Super B provides a Be In Charge Software tool, which can be used to read out the internal BMS system. The software uses a CAN to USB converter to connect to the communication interface. The software is capable of reading out the actual status, like battery/cell voltages and temperature, but also statistical information. Be In Charge software can also be used to update the installed firmware of the Li-ion battery. The Be In Charge software and hardware are not part of the Li-ion battery scope of delivery. Super B also provides a Be In Charge App for mobile devices such as Android and iOS. The app can be found in the Google Play Store or Apple App Store.
Is LiFePO4 Better Than Lithium-Ion?
Super B Batteries use LiFePO4, which surpasses lithium-ion in terms of safety, boasting a longer lifespan and greater thermal stability, making it ideal for prolonged use. While lithium-ion may be initially cheaper and require less upkeep, its susceptibility to overheating poses risks.
How do you connect the Super B Epsilon Battery?
There are several ways to connect the Super B Epsilon 12V150Ah Battery, as shown in our quick start guide, but the principle remains the same. For most installations, lift both sides of the battery to expose the plus and minus terminals, and attach the relevant connector to the battery terminal. The red cable goes to the plus "+" terminal on the battery, and the black cable goes to the minus "-" terminal. Please see our terminal connectors video for more information.
How do you troubleshoot Super B Epsilon Bluetooth issues?
There are a few easy fixes to troubleshoot Bluetooth connection issues. Our Bluetooth troubleshooting video explains more:
  1. Check if your "Be In Charge" application is up to date. You can find updates in the Apple App Store or Google Play Store.
  2. Update the battery from the top-right of the "Be In Charge" app.
  3. Electrically disconnect and reconnect the system. Contact Super B to guide you through this procedure.
  4. Ensure the plus and minus cables haven't short-circuited.
  5. Pressing the red S1 button should allow you to connect to the battery.
  6. Ensure sleep mode is deactivated on your phone or tablet and that you have a steady internet connection.
Epsilon 12V150Ah
Epsilon 12V100Ah
Nomada 12V105Ah
Nomia 12V210Ah
Nomia 12V340Ah
  • Ideal for larger RVs and commercial vehicles needing extra runtime without upsizing the install space; commercial marine vessels; stationary/off-grid backup where higher capacity per unit reduces battery count
  • Highest capacity in a standard-size casing; high discharge current; automatic heating for cold-weather charging; Bluetooth monitoring
  • Drop-in replacement (fits standard battery compartments, no system changes needed)
  • Low maintenance
  • Ideal power-to-weight ratio
  • High discharge currents
  • Low self-discharge
  • Fast charging
  • 3-year warranty
  • Ideal for motorsport/rally cars needing consistent high power output under stress; compact RV and campervan installs; leisure boats; cold-climate use where automatic heating matters
  • High capacity in a standard-size casing; high discharge current; automatic heating for cold-weather charging; Bluetooth monitoring
  • Low maintenance
  • Fast charging
  • 3-year warranty
  • Ideal for scalable installs: buses, trucks, material handling equipment, UPS systems, off-road vehicles; energy storage systems being sized/built up over time
  • Compact, lightweight; built as a modular system rather than a standalone battery
  • Add up to 4 in series/parallel (to 420Ah)
  • Low maintenance
  • Integrated BMS
  • Fast charging
  • 3-year warranty
  • Ideal for weight-sensitive mobile applications — campervans, leisure marine, powersports — where you want high capacity without the weight penalty
  • Traction battery
  • Low maintenance
  • Integrated BMS
  • Fast charging up to 210A
  • 3-year warranty
  • Ideal for large motorhomes and commercial marine vessels needing maximum onboard capacity; off-grid solar/renewable storage; heavy mobile machinery and industrial/automation systems where uptime is critical
  • Largest capacity in the traction battery range
  • Low maintenance
  • Integrated BMS
  • Fast charging up to 300A
  • 3-year warranty
  • Dimensions: 353 x 175 x 190mm
  • Weight: 15.5kg
  • Dimensions: 278 x 175 x 190mm
  • Weight: 10.7kg
  • Dimensions: 437 x 90 x 175mm
  • Weight: 10kg
  • Dimensions: 417 x 227 x 314mm
  • Weight: 23kg
  • Weight: 33kg
  • IP56
  • IP56
  • IP66
  • IP50
  • IP50
  • Epsilon 12V150Ah
  • Epsilon 12V100Ah
  • Nomada 12V105Ah
  • Nomia 12V210Ah
  • Nomia 12V340Ah
  • Energy: 1920Wh
  • Cycle Life: >5,000 (at 0.3C charge/discharge, 100% DoD), >3,500 (0.9C charge/discharge, 100% DoD)
  • Charge Voltage: 14.4V
  • Discharge Pulse Current (10 Sec): 350A
  • Charge Temperature (Heating Off): 0°C to 45°C
  • Charge Temperature (Heating On): -30°C to 45°C
  • Storage Temperature (<1 Month): -20°C to 45°C
  • Storage Temperature (>1 Month): 18°C to 28°C
  • Nominal Capacity: 100Ah
  • Energy: 1280Wh
  • Battery Designation: IFpP/27/148/135[2p4s] M/-20+60/95
  • Max Charge Current: 90A
  • Discharge Current Continuous: Max. 190A
  • Discharge Pulse Current (10 Sec): 300A
  • Nominal Capacity: 105Ah
  • Energy: 1344Wh
  • Cycle Life: >3,500 (at 100% DoD)
  • Case Material: PC - ABS | UL94-V0
  • Battery Designation: IFpP/36/130/195/[1P4S]M/-20+55/90
  • Max Charge Current: 105A
  • End of Discharge Voltage: 10V
  • Discharge Current Continuous: Max. 105A
  • Discharge Pulse Current (30 Sec): 315A
  • Charge Temperature: 0°C to 55°C*
  • Certifications: CE, UKCA, FCC, DNV, UN 38.3, UL 1642 (Cells), UN ECE R10.06, EN/IEC 62620 (ESTRIN)
* Do not charge below 0°C
  • Nominal Capacity: 210Ah
  • Energy: 2688Wh
  • Cycle Life: >3,500 (1C charge/discharge, 100% DoD)
  • Case Material: GFRP
  • Battery Designation: IFpP/36/130/195/ [2P4S]M/-20+55/95
  • Max Charge Current: 210A
  • Discharge Current Continuous: Max. 500A
  • Discharge Pulse Current (10 Sec): 800A
  • Storage Temperature (>1 Month): 0°C to 35°C
  • Certifications: CE, FCC, UN 38.3, UN ECE R10.06, UL 1642 (Cells), EN/IEC 62619-62620 (ESTRIN), RINA Type Approval
  • Nominal Capacity: 340Ah
  • Energy: 4352Wh
  • Cycle Life: >4,000 (0.5C charge/discharge, 100% DoD)
  • Battery Designation: IFpP/41/173/205/[2P4S]M/-30+60/95
  • Max Charge Current: 300A
  • Discharge Current Continuous: 300A
  • Discharge Pulse Current (30 Sec): 900A
  • Charge Temperature: 0°C to 60°C*
  • Discharge Temperature: -30°C to 60°C
  • Certifications: CE, UKCA, FCC, UN 38.3, UN ECE R10.06, UL1642 (Cells)
