Aim Taipan Motocross Engine Control Unit
The Taipan B Engine Control Unit (ECU) is our aftermarket plug & play ECU exclusively designed for the BETA Motors RX 450F 2025-2026. Thanks to its high-technology 32-bit core, it represents an important step forward to improve the performance of your motorcycle, without sacrificing reliability and smoothness.
Please Note: The Beta OEM idle motor is not compatible with our ECU. The Air Plug is therefore required when using the stock Beta throttle body setup.
If the throttle body is replaced with a non-Beta one, the AirPlug is not required.
Why Choose the Taipan B ECU
Engine control requires precision. With its high technology 32-bit core, at 20,000 RPM, the Taipan B ECU guarantees precision of 1/10 of a degree: this means an accuracy within 0.8 microseconds (µs) for turning the spark ON.
This precision is the key to guarantee:
  • A very consistent engine rotation.
  • The possibility of repeating dozens of tests at the bench, always obtaining the same result.
  • A perfect reactivity at every minimum change of any point of a map, resulting in more power at the wheel.
Aim Taipan B ECU for BETA Motors
BETA Motors RX 450F
The Beta RX 450 F is a competition-ready motocross bike, powered by a 449.3cc four-stroke engine and engineered for exceptional power, precision and control. Featuring advanced electronics, including traction control, launch control and quick shifting, it's built to deliver performance in demanding racing conditions.
The Aim Taipan B ECU is compatible with RX 450F years 2025 and 2026.
Handlebar Switch 2
You can choose from up to five selectable maps with the Handlebar Switch 2.
The Taipan can manage up to five maps that can be selected easily by the Aim Handlebar Switch 2.
HBS2 is the compact, high-performance, and durable Handlebar Switch.
If you're looking for a highly flexible and ergonomic switch, the model from Aim offers a great solution with 4 push buttons and 11 integrated LEDs.
  • Map Management
  • Fuel Trim
  • Traction Control Management
  • Launch Control Management
  • Buttons Setting Memorisation
HBS2 also allows the management of quick shifting on factory-equipped bikes.
Integrate FREE SPARK Software
SPARK is the intuitive software that lets you control, customise, and fine-tune your bike’s performance.
From map management to traction control, SPARK puts advanced tuning at your fingertips.
Thanks to the UC Bridge, designed to integrate Aim ECUs with the software, users can efficiently manage configurations, settings, and engine maps.
טעינת וידאו: Spark Software interface
UC Bridge License Types
UC Bridge is available in two distinct license types:
User License
This license provides end users with essential functionalities, including:
  • Receiving engine maps from your tuner and flashing them directly to the ECU
  • Displaying system exceptions or logged issues from the ECU within the SPARK software
  • Adjusting fuel injection corrections across various RPM ranges
Tuner License
Tailored for professional tuners, this license enables full control over map creation and configuration, including:
  • Designing and modifying base maps
  • Create custom maps from scratch
  • Managing configurations to be sent and applied to the ECU
Smoothing algorithm feature on Spark Software
Smoothing Algorithm
By selecting at least three contiguous cells and right-clicking, a context menu appears. Choosing ‘Smoothing’ from the menu applies the smoothing algorithm, which is also reflected in the 2D view.
3D visualisation on Spark Software
3D Visualisation
3D visualisation mode complements the 2D view. The 3D graph supports rotation, zooming, and panning, with controls detailed in the tab’s legend.
Tyre pressure sensor calibration gauge on Spark Software
TPS Sensor Calibration Gauge
TPS Sensor Calibration Gauge provide a clearer and more intuitive visualisation of the TPS signal voltage.
טעינת וידאו: Showcase of the Spark Software on mobile devices
Download the FREE SPARK App
SPARK is now available as a mobile app for both Android and iOS, with seamless Bluetooth connectivity to your bike.
Connect your smartphone to the Taipan and ECU in two ways:
  • Via the CAN-BT Module, for instant access to key engine data and real-time telemetry.
  • Using the XLog, if you want to collect data while driving as well.
The Taipan ECU Expansion list; Solo 2 DL, SmartyCam 3, Handlebar Switch 2, UC-Bridge and more
The Taipan B ECU works seamlessly with Aim’s ecosystem of devices.
  • CAN-BT Module: The CAN-BT Module grants instant access to key engine data from your Taipan ECU. Install the SPARK App on your smartphone for a streamlined, data-driven interface for real-time monitoring of live engine parameters.
  • Handlebar Switch 2: HBS2 is the compact, high-performance, and durable Handlebar Switch. If you're looking for a highly flexible and ergonomic switch, the model from Aim offers a great solution with 4 push buttons and 11 integrated LEDs.
  • UC-Bridge: The UC Bridge serves as the essential interface connection between the CAN bus of the ECU and the USB port of your PC.
  • Data Hub: Split EXP ports to connect multiple expansions such as the Solo 2 lap timer, UC Bridge, Handlebar Switch or additional converters.
2x 0-5V Analogue Inputs (1,000Hz Each) Can also be used as Switch to Ground
Second Injector Driver for High Impedance Saturated Injectors (12Oms)
One Low-Side Driver (1A)
CAN-Bus: x1 (for calibration purposes)
Power Consumption: 150 mA
Connectors:
n.1 JST 04T-JWPF-VSLE-S Connector
n.1 JST 08R-JWPF-VSLE-D Connector
n.1 36-Pin Male Connector
Body: PA6 + 30% Glass Fibre
Dimensions: 109.5 x 53.7 x 32.8mm
Waterproof: IP67
Weight: 150g approx
Part Number: XE1HBS200
Videos
טעינת וידאו: Plug & play installation of the Cobra ECU (now Taipan)
Taipan B User Guide
Taipan B Tech Sheet
Spark Tuning Software
Taipan Y V2
Made For:
  • 4-Stroke MX Bikes
  • Ducati Desmo450 MX
  • GASGAS EC 250F/EC 350F/MC 250F/MC 450F
  • Honda CRF 250R/CRF 450R/CRF 450L/CRF 450R
  • Husqvarna FC 250/FC 350/FC 450/FE 250/FE 350/FE 450/FE 501/FE 450 Supermoto
  • Kawasaki KX250/KX450
  • KTM SX-F 250/SX-F 350/SX-F 450/EXC-F 250/EXC-F 350/EXC-F 450/EXC-F 500/SMR 50
  • Various Years From 2019 to 2025
Made For:
  • 4-Stroke MX Bikes
  • BETA Motors RX 450F
  • Years 2025 & 2026
Made For:
  • 2-Stroke MX Bikes
  • GASGAS MC 125/MC 250
  • Husqvarna TC 125/TC 250
  • KTM SX 125/SX 250
  • Years 2024 to 2025
Made For:
  • 4-Stroke MX Bikes
  • Yamaha YZ250F/YZ450F
  • Years 2019 to 2023
Made For:
  • 4-Stroke MX Bikes
  • Years 2023 to 2025
  • Weight: 260g
  • Dimensions: 109.5 x 53.7 x 32.8mm
  • Weight: 150g approx
  • Dimensions: 64.5 x 59 x 29.5mm
  • Weight: 150g
  • Weight: 260g
  • Weight: 150g
  • IP67
  • IP67
  • IP67
  • IP67
  • IP67
  • Taipan Control Unit
  • Taipan B Control Unit
  • Taipan K Control Unit
  • Taipan Y Control Unit
  • Taipan Y V2 Control Unit
  • Analogue Inputs: Two 0-5V sampled at 1,000Hz each - could be alternatively used as a switch to ground
  • Second Injector Driver: (12Ω) for high impedance saturated injectors
  • Low-Side Driver: 1 (1A)
  • CAN Bus: 2 - one for calibration purposes, one for expansions (Aim Handlebar Switches, data loggers, dashes etc)
  • Power Consumption: 150mA
  • Body: PA6 + 30% glass fiber
  • Connectors:
  • 1 JST 04T-JWPF-VSLE-S connector
  • 1 JST 08R-JWPF-VSLE-D connector
  • 1 JST 04R-JWPF-VSLE-S connector
  • 1 33-pin male connector
  • Second Injector Driver: (12Ω) for high-impedance saturated injectors
  • CAN Bus: 1 for calibration purposes
  • Body: PA6 + 30% glass fibre
  • 2 JST JWPF waterproof auxiliary connectors
  • Connectors:
  • 1 36-pin male connector
  • Analogue Inputs: Two 0-5V analogue inputs sampled at 1,000Hz each - could be alternatively used as a switch to ground
  • Connectors:
  • Connectors:
  • Connectors:
How does the Aim Taipan ECU work?
The Aim Taipan ECU is a stand-alone engine control unit designed for motocross bikes. It replaces the stock ECU and manages fuel injection and ignition by continuously processing data from sensors such as throttle position, engine temperature and crank position.
Using programmable 3D fuel and ignition maps, it determines the precise injection timing and spark advance needed for optimal performance. The ECU also handles transient conditions like rapid throttle changes and can integrate additional inputs, such as Lambda sensors or handlebar switches, for features like closed-loop fuelling adjustments and map switching. This allows the engine to be precisely tuned for different conditions and performance goals.
Which motorcycle brands are compatible with the Aim Taipan ECU?
The standard Taipan ECU is compatible with a number of 4-stroke motorcycle brands, including Ducati, GASGAS, Honda, Husqvarna, Kawasaki and KTM. The Taipan K is compatible with selected 2-stroke GASGAS, KTM and Husqvarna models, and the Taipan Y ECUs are made for selected 4-stroke Yamaha models. For more information, please visit our compatibility page.
How accurate is the Aim Taipan ECU?
At 20,000 RPM, the Aim Taipan ECU guarantees a precision of 1/10th of a degree for ultimate accuracy and reliability.
Which products are compatible with the Aim Taipan ECU?
The Aim Taipan ECU is designed to work with other Aim products seamlessly to enhance performance monitoring. Some compatible Aim products include Solo 2 DL, Handlebar Switch 2, UC Bridge and CAN-BT Module.
What software can the Aim Taipan ECU use?
The Aim Taipan ECU can be used with our free SPARK software for tuning and analysing your data with ease and precision.
Can you customise the Aim Taipan ECU?
You can customise your Aim Taipan ECU by using our free SPARK software, allowing you to tailor engine performance, fuel injection, and ignition timing to your specific riding style.
