Advanced Motorsport Dash Logger
The MXP car dash display logger has a 6" TFT digital display, which has been designed to acquire and display data coming from the ECU. It is an ideal choice for racers who want valuable data at their fingertips but might be limited by space in the cockpit.
Note: The MXP Strada option is also available with road icons to suit a variety of vehicle applications.
The MXP Car Dash Display & Data Logger on a cockpit installation
Why Choose the MXP 6" Car Dash Display & Data Logger
The Aim MXP 1.3 is a compact, but powerful motorsport display and data logger. It offers real time data on its 6” TFT screen, has customisable display layouts, lap timing capabilities thanks to the GPS09 Module (included in the kit),and is compatible with a range of Aim devices and expansions for the ultimate setup.
Connecting the MXP 1.3 dash to your car's ECU is simple. You can sample dozens of channels straight from the ECU. This is usually the quickest and easiest setup, needing only a cable connection to the ECU instead of multiple connections and analogue sensors.
The sampled data will depend on your actual ECU, but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel ratio). The list of available ECU drivers is constantly updated and upgraded, and includes over 1,000 different ECUs.
Two Digital Outputs
The MXP car dash display logger features two digital outputs. Each of them can give an output of 1 amp at 12 volts. They can be configured to be turned on/off depending on the value of the analogue or digital inputs. They permit automatic running of external systems such as switching on/off additional lights, activating/deactivating a cooling fan or circulation pumps when a certain event happens.
With the CAN output, you can also send messages directly to an existing CAN network to improve the range of vehicle control possibilities.
Carica il video: Delta times LED display feedback on the MXP 6 inch data logger
Carica il video: Integrated shift light array interface and customisable alarms for the MX Series Data Logger
With integrated shift lights you can choose from a host of advanced multi-coloured RGB shift light patterns that can be customised to suit your requirements, and for each unique gear when required.
The MXP display logger also comes with 5 RGB LEDs, allowing you to customise colours, alarm types (solid or flashing), flashing frequency and accompanying text messages. Alarm priorities can be set to suit your specific requirements.
Carica il video: Pre-configured dash display screens for the MX Logger Series.
Configurable Pages
With a high contrast 6" TFT display, which is fully configurable, you can create and customise pages/displays to suit your requirements. Swapping pages can be managed by pushing one or two push buttons. An ambient light sensor adjusts the backlight for optimal brightness, ensuring clear visibility in all lighting conditions.
Two analogue camera inputs are available to switch your display into a mirror camera, through a push button command or event management. The camera is sold separately.
GPS Options
The included GPS09 module connected via CAN to the MXP dash logger makes lap time calculations and track position analysis easy. With 4,000+ worldwide tracks already stored with the start and finish line coordinates, you will have no problem when you're on the track.
As soon as the MXP is turned on, the GPS module will locate its position, identify track line coordinates and start immediately sampling lap and split time. If the track is not in the database, you can easily add the start/finish line coordinates to the MXP using our Race Studio 3 software.
Note: The GPS Module is available with cable lengths of 50cm, 1.3m, 2m or 4m, or a roof version with 2m or 4m length cables.
  • All channels
  • ECU drivers
  • Math channels
  • Display pages
  • Digital outputs
  • Alarms
  • Shift lights
  • Expansions
The SmartyCam series also connects to record synchronised video and telemetry ready for analysis in Race Studio 3.
  • Display: 6" TFT Display
  • Alarm LEDs: 5 RGB freely configurable
  • Shift Lights: 10 integrated, freely configurable RGB LEDs
  • CAN Connections: 3
  • ECU Compatibility: +1,000 industry-leading ECUs
  • Expansion CAN Connection: GPS, Channel Expansion, Thermocouple Expansions, Lambda Controller, SmartyCam
  • Analogue Inputs: 8 fully configurable, max 1,000Hz each
  • Second CAN: Yes
  • Accelerometer: Internal 3-axial ± 5G + 3-axial gyroscope+ 3-axis magnetometer
  • Wi-Fi Connection: Yes
  • Internal Memory: 4GB
  • Body: Anodised aluminium
  • Power Consumption: 400mA
  • Weight: 640g
  • IP67
SKU: MXP-CR4-XA6MXPA40R1
6" MXP Display Logger Diagram
6" MXP Display Logger Pinout
MX User Guide
MXP Tech Sheet
MXT Dash Display Logger
MXG Dash Display Logger
MXP Dash Display Logger
MXS Dash Display Logger
  • 10" TFT display
  • 10 shift light RGB LEDs
  • 3 CAN connections
  • GPS Module
  • 6 alarm RGB LEDs
  • 8 analogue inputs
  • 2 digital outputs
  • Wi-Fi connectivity
  • Integrated shift array
  • 7" TFT display
  • 3 CAN connections
  • GPS Module
  • 8 alarm RGB LEDs
  • 8 analogue inputs
  • 2 digital outputs
  • 6" TFT display
  • 3 CAN connections
  • GPS Module
  • 5 alarm RGB LEDs
  • 8 analogue inputs
  • 2 digital outputs
  • 5" TFT display
  • 3 CAN connections
  • GPS Module
  • 6 alarm RGB LEDs
  • 8 analogue inputs
  • 2 digital outputs
  • Weight: 1,200g
  • Weight: 950g
  • Weight: 640g
  • Weight: 530g
  • IP67
  • IP67
  • IP67
  • IP67
  • MXT Dash Logger
  • 37-Pin Standard Harness
  • GPS Module with Cable
  • MXG Dash Logger
  • MXP Dash Logger
  • MXS Dash Logger
  • Digital Outputs: 2 (1A max)
  • Second CAN: Yes
  • Body: Anodised Aluminium
  • Power Consumption: 450mA
  • Second CAN: Yes
  • Second CAN: Yes
  • Second CAN: Yes
  • Display: 10" TFT
  • Resolution: 1,280 x 480 pixels
  • Contrast: 1,100:1
  • Display: 7" TFT
  • Contrast: 1000:1
  • Display: 6" TFT
  • Display: 5" TFT
What size is the MXP Dash Display Logger?
The MXP features a 6", 800 x 480 pixel resolution display, making it one of the smallest displays in the MX Logger Series.
What alarms can be set on the MXP Display Logger?
The MXP Display Logger comes with 5 customisable RGB LEDs, which are determined by inputs from the car's ECU or other sensors. The MXP Dash Display Logger can be configured with alarms for gear position, lap time improvement, throttle position, low fuel, low oil pressure, low oil level and other customised alarms that have been set.
What are the best applications for the MXP Car Display Logger?
The MXP Car Display Logger is best suited to track day, race and high-performance road cars where drivers want live data, lap timing and detailed performance logging.
What are the differences between the MXP Logger and the MXP Strada?
The main difference between the MXP Logger and the MXP Strada Display is that the logger version has a built-in data logger. However, a Strada Logger can be purchased for the MXP Strada, which records data to an SD card. The MXP Logger also has 2 digital outputs, whereas the Strada only has 1. For a full comparison of the car MX Logger Series, take a look at the comparison tab.
Is the GPS Module included?
Yes, the Aim MXP 1.3 TFT Car Dash Display Logger comes with a GPS09 Module and cable. Choose between the standard version with 0.5m, 1.3m, 2m or 4m cable length options or the roof-mounted version with 2m or 4m cable length options.
How do I display gear information on my MXP Dash Display Logger?
Selected gear information can be sourced by gear potentiometer, ECU stream message, or it can be calculated in real time by the MXP Display Logger through speed and RPM. Each mode requires a specific gear configuration.
How do I connect & configure my SmartyCam with the MXP Display Logger?
To connect and configure your SmartyCam with MXP Display, you need to connect the devices, set up the configuration in Race Studio 3, and then transmit the configuration to the device. First, ensure your SmartyCam has power and a formatted SD card. Next, launch Race Studio 3 on your PC, which will detect the devices. Then, go to the "Configurations" page to create a new configuration or edit an existing one and add the "SmartyCam Stream" layer. In this layer, you will associate the necessary functions with the channels and transmit the configuration to the device.
