Aim Solo 2 DL RPM External Power Cable
Connect Your System
The Aim RPM Cable is used for vehicles when the particular ECU is not supported. When connected to the Solo 2 DL, a digital input is delivered from square wave signals or pulse signals. The full length of the cable is 2m, so it will fit your vehicle well but still remain compact in your Aim setup.
Why Choose the Aim RPM External Power Cable
As the Aim RPM External Power Cable is for unsupported ECUs, it allows you to expand your system, even with usually non-compatible products, so that you can track your laps and still make improvements. The cable length is a convenient size for your chosen vehicle, allowing you to use your Solo 2 DL Lap Timer and maximise your track days.
Note: This is one of the connection cables available for the Solo 2 DL. Others are the OBDII and the RS232/CAN cables.
Cavo di alimentazione esterno Solo 2 DL RPM
