Designed for Formula and Sports Cars
The Formula Steering Wheel 3 has been designed to work in conjunction wit the EVO4S or EVO5 loggers to display all of the real-time racing information in an efficient and easy to use interface.
Out of Production Formula Steering Wheel 3
Why Choose the Aim Formula Steering Wheel 3
The Aim Formula Steering Wheel 3 features a small, fully configurable graphical display that shows the data sampled by an EVO4S or EVO5 with a precise and efficient visualisation. You can keep constantly under control lap times and all values coming from the ECU, from the accelerometers and from the GPS (included in EVO4S/EVO5 kits).
Configurable LED Backlight
The screen can be backlighted in one of the seven available colors.
Individually Configurable LEDs
Six RGB shift lights can be configured for each gear, choosing LED colour and RPM threshold values which can turn it on/off.
Alarms LEDs are managed in a very flexible way: you can choose the event that generates the alarm, the LED behaviour (blinking frequency and colour) when the alarm appears, and the conditions for its switch-off.
A warning message can also be shown.
Easy Configuration
Shift Lights and Alarms are to be configured using Race Studio 3 configuration panel.
You can also select from up to 9 configurable display pages as you wish - The Formula Steering Wheel 3 swaps between these pages to show lap times and data in a 100% customisable way: just choose your data and create your pages displaying up to 8 fields each.
The "RPM and Lap Time" page layout is also available to display RPM Graph, Lap Time, and three channels of your choice.
External Functions
The Formula Steering Wheel 3 also features switch buttons to activate 4 functions among the options available in your car, such as your speed limiter, traction control, neutral, and more.
More Features
A key-data summary is available at the end of each session: the three best laps of the session with their times, min/max speed and min/max RPMs. In the following page you can also see a list of all the laps of the session.
You can also visualise the rolling time, static, or predictive lap time (as an absolute value or as a difference vs. the best lap).
SW4 270 (MY26) Formula Steering Wheel
  • CAN Connection
  • ECU Connection
  • Data Logging
  • Rotary Switches
  • Removable Handle Grips
  • Compact Display
  • CAN Connection
  • ECU Connection
  • Data Logging
  • Rotary Switches
  • Compact Display
  • CAN Connection
  • ECU Connection
  • Data Logging
  • Rotary Switches
  • Compact Display
  • Dimensions: 270 x 189.5 x 38.2mm
  • Weight: 1,500g
  • Weight: 2,400g
  • GT320 Dimensions: 320 x 183.5 x 42.5mm
  • GT350 Dimensions: 350 x 183.5 x 42.5mm
  • Weight: 2,600g
  • Chosen 270 Steering Wheel
  • Paddle Shifters
  • Standard Push-Button Kit
  • USB A – USB C Cable
  • 280 Steering Wheel
  • Chosen GT32 or GT350 Steering Wheel
  • Shift Lights: 8 configurable RGB LEDs
  • Ambient Light Sensor: Yes
  • CAN Connections: 3
  • ECU Connection: CAN
  • ECU Compatibility: 2,000+ industry-leading ECUs
  • Expansion CAN Connection: CAN Connection: GPS Module, LCU Series, ACC3, SmartyCam 3 Series, RIO02, Shift Light Module, Memory Module
  • Connectors: 1 Autosport 22-pin male connector (coiled cable only) or none/free wires (quick release only) + 1 USB-C connector
  • Push Buttons: 10 push buttons & 0/1/3 rotary switches (all with RGB backlights)
  • Power Consumption: 500mA
  • Internal Memory: 4GB
  • Body: Carbon fibre-reinforced resin and forged metal
  • ECU Compatibility: 1,000+ industry-leading ECUs
  • Expansion CAN Connection: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam, RIO Module, GS-Dash, Memory Module
  • Connectors: 1 Deutsch Autosport 22-pin male connector
  • Push Buttons: 10 push buttons & 3 rotary switches (all with RGB backlights)
  • Display: 4.3" TFT
  • Contrast: 800:1
  • Brightness: 800 cd/m2
  • Display: 4.3" TFT
  • Contrast: 800:1
  • Display: 5" TFT
  • Contrast: 800:1
What is the Aim SW4 Formula Steering Wheel collection?
The Aim Formula SW4 collection is a range of high-performance steering wheels that are designed for single-seater motorsports. They are made to be versatile and compatible with many different racing applications and include a range of key features.
The Aim SW4 range comes in multiple sizes and has a memory of 4GB. It allows for real time data to be shown, making it easy for drivers to see where they are and to make changes based on it. You can also expand your system with GPS modules and the SmartyCam 3 through its CAN connectivity. This steering wheel is the perfect product for racers looking to upgrade their driving and data logging capabilities.
Are SW4 Formula Steering Wheels compatible with Aim devices & data logging systems?
Aim SW4 Steering Wheels are compatible with other Aim devices and data logging systems, such as the ACC3 Analogue CAN Converter, SmartyCam Cameras and various sensors. This allows for a more detailed and advanced data collection and analysis, making it a very versatile product for different motorsport applications.
What sizes do the Aim SW4 Steering Wheels come in?
The Aim SW4 Steering Wheel range is available in 4 sizes (270, 280, 320 and 350mm) for different racing applications and cockpit space available. Please see our SW4 guide for more information on which sizes are best-suited to your setup.
How do you install a Formula Steering Wheel in a cockpit?
Regardless of which steering wheel you are most interested in, connecting the Formula 4 Steering Wheel to the vehicle’s ECU is extremely easy. Start by securely mounting the wheel to your vehicle. Once the wheel is in place, you can then connect it to the ECU using the Deutsch connector harness.
After the wheel is in place and connected, Race Studio 3 software can be used to customise display pages, alarms and shift light settings according to your preferences. Please test the setup thoroughly to ensure that all functions are working correctly.
