コンテンツへスキップ
ログイン
検索
検索 ログイン カート 0
カート
  • お買い物を続ける
あと £50.00で送料無料です!
    特別注文
    税および送料はチェックアウト時に計算されます。
    小計(税込)
    カートを見る
    検索
    Super B Andrena 12V2.5Ah Lithium Kart Battery - AimShop.com
    SB12V2600P-AC
    在庫あり、出荷準備中
    Shop by vehicle
    Car
    Kart
    £155.00
    このアイテムは定期購入または後払い購入です。続行することにより、キャンセルポリシーに同意し、注文がフルフィルメントされるまで、もしくは許可される場合はキャンセルするまで、このページに記載されている価格、頻度、日付で選択した決済方法に請求することを承認するものとします。
    • Facebookにシェア
    • 共有する
    • 共有する
    • Facebook Facebookにシェア
    • WhatsApp 共有する
    • E-mail 共有する
    £155.00
    Super B Andrena 12V2.5Ah Lithium Battery
    Light-weight, high-performance, safe, and reliable lithium power battery, specially developed for motorsports. This battery equals a lead-acid battery of 5 to 7Ah, provided the alternator’s maximum current doesn’t exceed the battery’s maximum charge current of 10A. Designed in a standard rally casing. Suitable for 12V systems and for use in extreme environments.
    Lightweight Power
    With a weight of only 0.46kg /1.0lbs, the Andrena 12V2.5Ah power battery saves up to 80% in weight in comparison to traditional lead-acid batteries and is only 1/3 of the size of a conventional battery. This improves not only the performance of your vehicle but also helps to increase the fuel economy.
    The power battery offers a high level of power, fast charging, and long, maintenance-free service life. It also has a stable and flat discharge which means you have over 80% of the battery's capacity available and you can leave your vehicle unattended for a much longer period compared to a lead-acid battery.
    Safe & Reliable
    Super B batteries are based on lithium iron phosphate technology (LiFePO4). This is the safest lithium technology available today. On top of that our bespoke casing and electronics further increase safety and durability. Due to its high ingress protection class (IP69), the battery is completely dust-tight and waterproof. Therefore the battery can be used in the most extreme environment as well.
    Performance
    Fast charging
    Lightweight
    Compact size
    Low self-discharge
    High discharge rates
    3 Year Warranty
    Specification
    ELECTRICAL SPECIFICATIONS
    Nominal Capacity 2.5Ah
    Energy 32Wh
    Nominal Voltage 12.8V
    Open Circuit Voltage 13.2V
    Self Discharge <3% per month
    EqPb (Equals lead-acid) 5 to 7Ah
    MECHANICAL SPECIFICATIONS
    Dimensions (LxWxH) 114 x 32 x 84mm | 4.49” x 1.26” x 3.30”
    Weight 0.46 kg / 1.0lbs
    Case Material PC - ABS
    Ingress Protection IP69
    Charge Method CCCV
    Charge Voltage 14.3V - 14.6V
    Max Charge Current 10A
    End of Discharge Voltage 8V
    Discharge Current Continuous 40A
    Discharge Pulse Current (1 sec) 136A (54C)
    TEMPERATURE SPECIFICATIONS
    COMPLIANCE SPECIFICATIONS
    EAN-13 8718531360006
    Battery Designation 4IFpR27/66
    Quickstart Guide
    Available to download Here
    User Manual
    Quickstart Guide
    Safety Data Sheet
    • よくある質問
    • ソフトウェア
    • ウェビナートレーニング
    • 製品ガイドPDF
    • ニュースレター
    • お問い合わせ
    • アフィリエイトになる
    • 修理
    • ライブチャットとサポート
    • 選択をするとページが更新されます。
    • 新しいウィンドウで開きます。
