Compact 5” Dash Display
The MXS 1.3 Strada with race icons is one of the most widely used dash displays on tracks around the world due to its ability to show data coming from the ECU. Its compact size, paired with race icons, makes the MXS 1.3 Strada a go-to choice for compact motorsport setups.
The MXS Strada Display is an HD digital display, designed for motorsport drivers who need essential data visibility while on the track or road. The dashboard is tailored to show real time data such as speed, RPM and temperatures, but doesn't include data logging functionalities natively.
The MXS 1.3 Strada is available with a choice of connections. Choose either the OBDII or K-Line CAN, depending on whether you want to connect to the car's ECU or OBDII port or directly to the ECU through the CAN channel.
You can sample and display dozens of channels straight from the car’s ECU with only 2 cable connections to the ECU instead of multiple connections to analogue sensors. The sampled data depends on the actual ECU, but will typically include RPM, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear, and lambda value (air/fuel ratio). The list of available ECU drivers is over 1,000 and is constantly being updated.
Digital Outputs
The MXS 1.3 Strada features a 1-AMP digital output configurable to be activated/deactivated depending on the value of the analogue/digital inputs or on the impulses coming from the car’s ECU. This allows you to automatically run external systems, such as switching on/off additional lights, to activate/deactivate a cooling fan or circulation pumps when a certain event happens.
Load video: Delta times LED display feedback on the MXS 5 inch Strada Display
Display with Race Icons
The MXS 1.3 Strada has a 5" TFT high contrast colour display. The visual quality is optimised by the ambient light sensor, which keeps the backlight at the best brightness levels. Race icons allow you to apply conditions to the LED icons.
Pre-Configured Pages
Connecting an MX Strada Logger to your display enables it to log your data. With Race Studio 3, available to download on desktop or our mobile app, you can create, modify, delete, import and export configurations of:
  • All channels
  • ECU drivers
  • Math channels
  • Display pages
  • Digital outputs
  • Alarms
  • Shift lights
  • Expansions
Please Note: A 14-pin harness comes standard in the kit. Should you need more data, you can add our 23-pin harness as an optional extra.
  • Ambient Light Sensor: Yes
  • CAN Connections: 2
  • Second CAN: Yes
  • Body: Anodised aluminium
  • Power Consumption: 400mA
  • Display: 5" TFT
  • Contrast: 600:1
  • Weight: 480g
SKU: MXS-S
MXS Strada User Guide
MXS Strada Tech Sheet
What does the MXS Strada do?
The Aim MXS Strada is a digital dash display that can be configured to show real time information from the car's ECU, analogue/digital inputs, predefined math channels and an optional GPS Module. It provides crucial information like speed, RPM, water temperature, and oil pressure on a high-contrast TFT screen.
What size is the MXS display?
The MXS Strada comes with 6 customisable RGB LEDs, which are determined by inputs from the car's ECU or other sensors. The MXS Strada with race icons can be configured with alarms for low fuel, high/low pressures, high/low temperatures, over-rev limits and other customised alarms that have been set.
What are the best applications for the MXS Strada with race icons?
The MXS Strada with race icons is best suited to performance driving like track day racing and compact car cockpits.
The main difference between the MXS logger and the MXS Strada display is that the logger version has a built-in data logger. However, a Strada Logger can be purchased for the MXS Strada, which records data to an SD card. The MXS logger also has 2 digital outputs, whereas the Strada only has 1. For a full comparison of the MX Strada Series, take a look at the comparison tab.
How do you switch between pages on the Aim MXS Strada?
To switch pages on the Aim MXS Strada, first open our free Race Studio 3 software and then select the Page Configuration to customise each page. After choosing your selections, save your configurations and press the ">>" push button on the side of the device to switch between your pages.
How do I connect my MXS Strada to my car’s engine control unit (ECU)?
How do I connect my MXS Strada to the car’s OBDII connector?
Use a dedicated OBDII wiring harness and configure the MXS Strada with Race Studio 3. The process involves a physical connection followed by software setup to identify your car's specific ECU protocol. More information can be found here.
MXT Strada
MXG Strada
MXP Strada
MXS Strada
  • 10” TFT display
  • 10 shift light RGB LEDs
  • CAN output
  • 6 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • 7" TFT display
  • CAN output
  • 8 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • 6" TFT display
  • CAN output
  • 5 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • 5" TFT display
  • CAN output
  • 6 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • Weight: 1,100g
  • Weight: 950g
  • Weight: 590g
  • Weight: 480g
  • IP67
  • MXT Strada Dash
  • 14-Pin Standard Wiring
  • MXG Strada Dash
  • MXP Strada Dash
  • MXS Strada Dash
  • Second CAN: Yes
  • Body: Anodised Aluminium
  • Power Consumption: 450mA
  • Second CAN: Yes
  • Second CAN: Yes
  • Second CAN: Yes
  • Display: 10" TFT
  • Contrast: 1,100:1
  • Display: 7" TFT
  • Contrast: 1000:1
  • Display: 6" TFT
  • Display: 5" TFT
