    Super B Nomia 12V210AH Lithium Traction Battery - AimShop.com
    SB-E-210
    Super B Nomia 12V210Ah Lithium Traction Battery
    In stock, ready to ship
    £2,140.00
    £2,140.00
    The Super B Nomia 12V210Ah is a lighter (23kg vs 33kg) and lower capacity version of the Nomia 340Ah, making it ideal for weight-sensitive setups like campervans and mobile applications
    superb lithium batteries
    What Is The Super B Nomia 12V210AH Lithium Traction Battery?
    The Super B Nomia 12V210AH Lithium Battery is a state-of-the-art Lithium Iron Phosphate battery (LiFePO4) designed for traction and energy storage applications. Its advanced technology and smart software makes this lithium battery a robust, low-maintenance, high-efficiency, safe and user-friendly energy storage solution, offering significant weight and space savings compared to traditional lead-acid batteries.
    Product Features
    Traction battery
    Lithium Iron Phosphate (LiFePO4): Safe Li-Ion technology
    Integrated BMS (Battery Management System), external disconnect device needed
    Glass fibre reinforced plastic (GRFP) Casing, Aluminium / PE sandwich side panels
    Terminals for 2 x M8 bolts
    Integrated fuse, 32V / 500A
    Wired communication interface: CAN open
    Battery monitoring / History storage
    Adaptive cell balancing
    Configurable in serial or parallel connection
    Output for bistable relay/latching relay
    Weight & space-saving battery
    Intended Use
    The Nomia 12V210AH Li-Ion battery is ideal for recreational vehicles, commercial vehicles, leisure boats, commercial vessels and stationary applications.
    Potential applications of this Li-Ion battery include: off grid power supply, marine power supply, medium for (renewable) energy storage and (traction) battery for vehicles.
    Note: This battery is not suitable for use as a starter battery. Up to 4 batteries can be connected in series or in parallel to increase the total capacity up to 840Ah. For more batteries, consult with Super B for guidance.
    Why Choose The Super B Nomia Battery
    Low maintenance
    Low maintenance
    Fast charging
    Fast charging
    Safest lithium technology
    High discharge currents
    High capacity
    High capacity
    Low weight
    Low weight
    High cycle count
    High cycle count
    Low self-discharge
    Low self-discharge
    The Super B Nomia 12V210Ah Lithium battery stands out for its high energy capacity (210Ah) and advanced LiFePO4 technology, offering superior safety, longevity and performance. It provides reliable protection against overcharging, deep discharging and overheating, contributing to its long cycle life of over 3,500 cycles at 100% depth of discharge.
    Despite its strong output, the battery remains compact and lightweight at just 23 kg, making it ideal for space-sensitive applications. The Nomia also supports fast charging up to 200A, delivers high discharge currents and has a low self-discharge rate under 3% per month. Overall, it offers a reliable, low-maintenance power solution for a variety of setups.
    CERTIFICATIONS
    UN ECE CE FCC UL Certified UN38.3 RINA ES TRIN
    3-Year Warranty
    A 3-year warranty offers the best peace of mind. It is the benefit of years of continuous engineering improvement and proven experience with all Super B batteries in the harshest environments.
    3 year warranty
    The Super B Nomia 12V210Ah Lithium Traction Battery is a cutting-edge lithium battery designed for use in electric vehicles, golf carts, forklifts and other traction applications. With a capacity of 200 amp hours and a voltage of 12 volts, this battery offers superior performance and reliability compared to traditional lead-acid batteries.
    One of the key advantages of the Super B Nomia 12V210Ah Lithium Traction Battery is its lightweight and compact design. Weighing just a fraction of what a traditional lead-acid battery weighs, this lithium battery is much easier to handle and install, making it ideal for applications where space and weight are at a premium. Additionally, the Super B Nomia battery has a long cycle life, with the ability to withstand thousands of charge and discharge cycles without losing capacity.
    Another important feature of the Super B Nomia 12V210Ah Lithium Traction Battery is its fast charging capabilities. With a high charge acceptance rate, this battery can be recharged quickly, reducing downtime and allowing for more efficient use of the equipment it powers. This makes the Super B Nomia battery an excellent choice for applications that require frequent and rapid charging.
    Testimonials
    "These batteries are a game-changer for living off grid and we know, from talking to our fellow cruisers, that we are not the only ones making this change to lithium. Super B are the best in the business. As we continue our journey round the world we feel safe in the knowledge these may be the last set of batteries we ever need to install." -Sailing Fair Isle ...More
    "We have 8 lithium iron phosphate batteries (LiFePO4) at the core of our sailing yacht, a massive upgrade from the old lead-acid. The simplicity of installation, quality, and durability made this a no-brainer!" -Feel the Breeze ...More
    Specifications
    ELECTRICAL SPECIFICATIONS
    Nominal capacity
    210Ah
    Open circuit voltage
    13.2v
    self-discharge
    <3% per month
    Cycle Life
    >3,500 cycles (at 1C charge/ discharge, 100% DoD)
    Voltage
    12v
    MECHANICAL SPECIFICATIONS
    Dimensions (LxWxH)
    417 x 227 x 314 mm / 16.4” x 8.9” x 12.4”
    Weight
    23kg / 50.7lbs
    Case material
    GFRP
    Ingress protection
    IP50
    Cell type / Chemistry
    Prismatic - LiFePO4
    Charge method
    CCCV
    Charge voltage
    14.3V - 14.6V
    Max. charge current
    200A
    End of discharge voltage
    10V
    Discharge current continuous
    200A
    Discharge pulse current
    600A (30 sec)
    TEMPERATURE SPECIFICATIONS
    Charge temperature
    0°C to 55°C / 32°F to 131°F
    Discharge temperature
    -20°C to 55°C / -4°F to 131°F
    Storage temperature
    -20°C to 45°C / -4°F to 113°F
    COMPLIANCE SPECIFICATIONS
    Certifications
    CE, FCC, UN 38.3, UN ECE R10.06, UL 1642 (Cells), EN/IEC 62619-62620 (ESTRIN), RINA Type Approval
    Shipping classification
    UN 3480
    GENERAL SPECIFICATIONS
    EAN-13
    8718531361645
    Battery designation
    IFpP/36/130/195/ [2P4S]M/-20+55/95
    Quickstart Guide
    Available to download Here
    Mobile App
    Super B provides a Be In Charge Software tool which can be used to read out the internal BMS system. The software uses a CAN to USB converter to connect to the communication interface. The software is capable of reading out the actual status like battery / cell voltages and temperature but also statistical information. The Be In Charge software can also be used to update the installed firmware of the Li-ion battery. The Be In Charge software and hardware are not part of the Li-ion battery scope of delivery. Super B also provides a Be In Charge App for mobile devices such as Android and Apple. The app can be found in the Google play store or Apple app store.
    superb app
    User Manual
    Quickstart Guide
    Charging Manual
    Data sheet
    Safety Data Sheet
    CAD File
