Upgrade your powerboat setup with one of the best powerboat lap timers in the industry — the Solo 2 DL GPS lap timer. Display instant speed, timing splits, live data and delta lap times on a high-contrast display with an accuracy of up to two-hundredths of a second.
See your exact sailing line, compare it to optimal lines for faster times, track your boat’s movements and provide detailed data from bow to stern. Do all of this and more with direct data logging for instant or post-race analysis with all your logged performance data.
Why Choose the Powerboat Solo 2 DL
Building on the features of the Aim Solo 2 model, the Solo 2 DL powerboat lap timer connects directly to your boat to record vital data, without the need for complex wiring. Compatible with a wide range of motorsport applications and ECUs, the Solo 2 DL is a versatile tool for helping motorsport professionals monitor and improve their performance in any motorsport discipline.
Solo 2 DL track recognition
On-Screen Delta Feedback
The Solo 2 DL has a sharp, high-contrast display which helps you to easily identify the data displayed on screen, as well as 8 different backlight colours.
Thousands of pre-loaded worldwide maps are available, the lap timer automatically recognises your position as soon as it's switched on. Once you go, it automatically recognises the start line coordinates and starts sampling lap times every time you go past.
The Solo 2 DL allows you to create a new temporary or permanent map layout too. Even if there is no map already, the device will create one for you.
Inertial Platform
Mounting Options
To take your data one step further, the Aim Solo 2 DL powerboat lap timer seamlessly connects to Aim SmartyCams and a variety of vehicle sensors to increase your data performance and enhance your analysis with the added visuals and overlays, as well as additional sensor information.
  • Display: Graphical LCD
Integrated Track Database
  • Over 4,000 worldwide
  • Wi-Fi Connection: Yes
  • GPS: 25Hz
  • External Power: 9-15V
  • Memory: 4GB
SKU: SOLO2-k2
Solo 2 DL pinout
  • Solo 2 DL front view
    Solo 2 DL
  • Cable icon
    Wall Charger with AC Adapter
  • Cable icon
    Your Chosen Connection Cable
Solo 2 DL User Guide
Solo 2 DL Tech Sheet
Videos
Overview
Załaduj wideo: An in-depth review of the main features and functions of the Aim Solo 2 DL powerboat lap timer.
What is the best GPS lap timer?
The Aim Solo 2 DL is a high-precision, 25Hz GPS lap timer. It connects directly to your powerboat’s ECU to provide detailed performance data such as speed, RPM, throttle position and more. It provides accurate lap times, split times and predictive timing, with advanced data logging capabilities, making it one of the best compact data logging lap timers with an integrated display.
How does the Aim Solo 2 DL powerboat lap timer work?
The Aim Solo 2 DL is a data logging GPS lap timer that allows you to analyse instant speed, timing splits, live data and predictive, theoretical and delta times. It connects directly to the powerboat's ECU and multiple satellite constellations (GPS and GLONASS), providing performance data in real time.
The Aim Solo 2 DL uses a range of different technologies to enhance user experience. It has a 25Hz GPS receiver for precise lap timings and position markers, a 100Hz 6-axis inertial platform that provides data on roll, pitch and yaw. It also has integrated data logging capabilities via CAN bus, for advanced and comprehensive data logging.
How do you connect the Aim Solo 2 DL to the powerboat's system?
The Aim Solo 2 DL manages all the hardware ECU connections as well as all the communication lines: CAN, RS232 or K-Line. Choose between the CAN/RS232 external power cable, CAN/K-Line/external power cable with the OBDII connector or RPM/external power cable.
Yes, the Aim Solo 2 DL is compatible with other Aim products, acting as a central hub for motorsport data acquisition. It features an expansion port (via CAN connection) that allows for easy integration of additional sensors and systems.
The Solo 2 DL can work seamlessly with our SmartyCam series for data overlay and high-quality recordings. It can also be paired with an Aim ACC3 to add 4 additional analogue channels for external sensors. Data Hubs can also be added to the system to provide additional CAN channels, which is ideal if you're already using the CAN expansion port. Please see the "Connections" tab for more examples.
Aim Solo 2 DL
Aim Solo 2
  • 4GB Internal Memory
  • Automatic Track Recognition
  • Integrated GPS
  • Ten Configurable RGB LEDs
  • Wi-fi Connectability
  • GLONASS Receiver
  • Direct ECU Data Logging
  • Predictive Lap Timing
  • Choice of Connection
  • Integrated GPS
  • Graphical Display
  • Solo 2 DL
  • Choice of connection Cable
  • Solo 2
  • GPS: 25Hz
  • Memory: 4GB
  • GPS: 25Hz
  • Memory: 4GB
