Aim MXS 1.3 5" TFT Powerboat Dash Display Logger
Choose Accessories
Compact Powerboat Dash Logger
The MXS 1.3 powerboat dash logger has a 5" TFT digital display which has been designed to acquire and display data coming from the ECU. It is an ideal choice for sailors who want valuable data at their fingertips.
Why Choose the MXS 5" Powerboat Dash Display & Data Logger
The Aim MXS 1.3 is a compact, but powerful motorsport display and data logger. It offers real time data on its 5” TFT screen, has customisable display layouts, lap timing capabilities thanks to the GPS09 Module (included in the kit), and is compatible with a range of Aim devices and expansions for the ultimate setup.
A Range of Data Sources
Connecting the MXS 1.3 dash to your powerboat's ECU is simple. You can sample dozens of channels straight from the ECU. This is usually the quickest and easiest setup, needing only a cable connection to the ECU instead of multiple connections and analogue sensors.
The sampled data will depend on your actual ECU, but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel ratio). The list of available ECU drivers is constantly updated and upgraded, and includes over 1,000 different ECUs.
Pre-Configured Pages
Two analogue camera inputs are available to switch your display into a mirror camera, through a push button command or event management. The camera is sold separately.
- All channels
- ECU drivers
- Math channels
- Display pages
- Digital outputs
- Alarms
- Shift lights
- Expansions
GPS Module
The GPS09 module, connected via CAN to the MXS dash logger, makes lap time calculations and position analysis easy. With 4,000+ worldwide tracks already stored with the start and finish line coordinates, you will have no problem when you're on the course.
As soon as the MXS is turned on, the GPS module will locate its position, identify course coordinates and start immediately sampling lap and split time. If the track is not in the database, you can easily add the start/finish line coordinates to the MXS using our Race Studio 3 software.
Note: The included GPS Module is available with 0.50m, 1.3m, 2m or 4m length cables. We also have an option for a roof-mounted version, which is available with 2m or 4m length cables.
Please Note: A 37 pin harness comes standard in the kit. Should you need more data, you can add our 22 pin harness as an optional extra.
MXS 1.3 Dash
Harness
GPS Module with Cable
USB Cable
| Specs |
MXS Dash Display Logger
MXG Dash Display Logger
