Skip to product information
1 of 3
Aim Two-way Data Hub CAN Connection Multiplier with External Power
SKU: S-2PH-K
£65.00
£78.00
INC VAT - UK only
£65.00
£65.00
£78.00
INC VAT - UK only
£65.00
The Aim two-way Data Hub provides CAN channels and works as an interface between our Aim loggers and sensors. It also features a 12V external power connection.
Key Features:
Five pins 712 male Binder Two-way hub
Two flying cables Build a network
Two-Way Data Hub with External Power Connection
The compact two-way data hub with 12V flying leads provides CAN channel and works as an interface between Aim loggers and equipment such as LCU lambda controller, GPS module, TC hub, SmartyCams and many more.
The two-way Data Hub takes all the information you need to your logger with only one cable, minimising wires overall.
Our Data Hubs are also available in the following versions:
  • Four-way data hub
  • Two-way data hub
Connecting the Two-Way Data Hub
The two-way data hub with external power allows you to connect different devices, powering them through a battery.
You can connect more Data Hubs to build a network, as shown in the image below. This is ideal if you want to add extra data to your vehicle for improving performance and data.
Two-way Data Hub CAN Connection Multiplier Connection Example
  • Dimensions: 70 x 30 x 23.5mm
  • CAN cable length: 40cm
  • Source cable length: 165cm
  • Weight: 86g
  • 5 pin 712 male Binder connection
  • Two flying leads 12V
Two-way Data Hub Pinout
  • x 1 Two-way Data Hub with external power
Key Features:
The compact two-way data hub with 12V flying leads provides CAN channel and works as an interface between Aim loggers and equipment such as LCU lambda controller, GPS module, TC hub, SmartyCams and many more. Using many devices can result in excessive wiring. Thanks to the data hub, it can eliminate all unnecessary wiring. The two-way Data Hub takes all the information you need to your logger with only one cable, minimising wires overall. Our Data Hubs are also available in the following versions:
  • Four-way data hub
  • Two-way data hub
The two-way data hub with external power allows you to connect different devices, powering them through a battery. You can connect more Data Hubs to build a network, as shown in the image below. This is ideal if you want to add extra data to your vehicle for improving performance and data. Two-way Data Hub CAN Connection Multiplier Connection Example
  • Weight: 86g
