The Aim Expansion Power Module 08 (EPM)
The Expansion Power Module adds power outputs to your installation. They are available in two variants, the EPM08 with 8 power outputs, and the EPM32 with 02 power outputs.
Why Choose the EPM08?
The EPM08 allows for 8 power outputs and is compatible with the Aim MXS Series and the Steering Wheel 4. With 6 fully configurable analogue inputs at 500Hz each, digital inputs, and a max current of 100A, they are perfectly suited for adding extra power to your PDM08.
Connectivity
The Aim EPM range includes powerful systems such as the 8-channel EPM and the versatile 32-channel EPM, giving you the flexibility to choose the ideal setup for your specific needs. Featuring 2 CAN networks, these expansion power modules are controlled by the Aim Exp connection.
The EPM connects to an existing Aim PDM, Steering Wheel 4, or a dash display/logger from the Aim MX range. These devices control the vehicle's power without the need for fuses or relays, with outputs that can deliver up to 35A individually.
If connected to a logger, they will also allow the recording and analysis of where every amp is used. A Strada dash will also allow the power control, but without the logging ability.
  • Connector: 1 AMP connector + 1 Amphenol Surlok connector
  • LEDs: 8 RGB LEDs + 1 EPM ON + 1 EPM STS (status)
  • Body: Anodised aluminium
Inputs
  • Analogue Inputs: 6 fully configurable analogue inputs (0-5V; 0-12V) recorded at max 500Hz each
  • Digital Inputs: Pull-up/pull-down
Power Outputs
  • 1 with series diode rated up to 20A (high side)
  • 1 rated up to 25A (high side)
  • 6 rated up to 15A (high side)
  • Protected For: overvoltage, undervoltage, short circuit, overcurrent and overtemperature
  • Total Max Current: 100A
  • Dimensions: 161 x 100.6 x 50.6mm
  • Weight: 370g
SKU: EPM
Part Number: XEPM0800
EPM08 diagram
EPM08 pinout
EPM08 Tech Sheet
  • 6 Analogue Inputs
  • 8 RGB LEDs
  • 8 Power Outputs
  • Power Module Expansion
  • 8 Analogue Inputs
  • 32 RGB LEDs
  • 32 Power Outputs
  • 6 Analogue Digital Inputs
  • 8 RGB LEDs
  • 2 Speed Inputs
  • Power Outputs
  • GPS Lap Timing (Optional)
  • Data Logging
  • 8 Analogue Digital Inputs
  • 32 RGB LEDs
  • 2 Speed Inputs
  • 4 Digital Inputs
  • Data Logging
  • Weight: 370g
  • Dimensions: 234.4 x 95.1 x 49mm
  • Weight: 740g
  • Weight: 500g
  • Dimensions: 234.5 x 94.6 x 49.5mm
  • Weight: 761g
  • EPM08 Unit
  • EPM32 Unit
  • PDM08 Unit
  • SurLok Power Connector
  • Black 35-Pin Plug & Pins
  • CAN Expansion Cable
  • Download Cable
  • PDM32 Unit
  • Grey & Black 35-Pin Plug & 70 Gold Pins
  • Download Cable
  • Inputs: 6 fully configurable analogue inputs (0-5V; 0-12V) recorded at max 500Hz each, pullup/pulldown digital inputs
  • Power Outputs:
  • 1 with serie diode rated up to 20A
  • 1 rated up to 25A
  • 6 rated up to 15A
  • Protected for: over voltage, under voltage, short circuit, over current and over temperature
  • Connectors: 1 AMP connector + 1 Amphenol SurLok connector
  • LEDs: 32 RGB LEDs + 1 EPM ON + 1 EPM STS (status)
  • Inputs: 12 analogue inputs recorded at max 500Hz each (8 configurable as analogue or digital, 4 digital only), pullup/pulldown digital inputs
  • Power Outputs:
  • 3 rated up to 20A
  • 12 rated up to 15A
  • 12 rated up to 10A
  • 4 rated up to 35A
  • Total Max Current: 120A
  • Connectors: 2 AMP connectors + 1 Amphenol SurLok connector
  • LEDs: 8 RGB LEDs, 1 PDM ON & 1 PDM STS (status)
  • Inputs: 6 fully configurable (max 500Hz each), pullup, pulldown & analogue/digital, 2 speed inputs
  • Power Outputs:
  • 1 rated up to 25A
  • 6 rated up to 15A
  • Protected for: over voltage, under voltage, over current, over temperature
  • All outputs have internal freewheeling diode
  • Total max current: 100A
  • Lin Bus: 1
  • CAN Connections: 3
  • Internal Platform: 3-axis ±5G accelerometer, 3-axis gyro & 3-axis magnetometer
  • Internal Memory: 4GB
  • External Modules: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam, Formula Steering Wheel, Memory Module, Remote I/O Push-Button Module
  • External Analogue Camera Input: No
  • Connectors: 1 AMP connector, 1 Amphenol SurLok connector & 1 Rosenberger connector
  • Remote Display Connection: 1 Aim stream output
  • LEDs: 32 RGB LEDs, 1 PDM ON & 1 PDM STS (status)
  • Inputs: 14 fully configurable (max 500Hz each) - 8 analogue/digital, 4 digital inputs, 2 speed inputs
  • Power Outputs:
  • 4 rated up to 20A
  • 4 rated up to 35A
  • Total max current: 120A
  • Lin Bus: 1
  • External Analogue Camera Input: 2
  • Connectors: 2 AMP connector, 2 binder connectors, 1 Amphenol SurLok connector & 1 Rosenberger connector
  • Displays sold separately
