Aim Cable conector de alimentación externa OBDII Solo 2 DL
Solo 2 DL Power Connector
The Aim OBDII 2m external power cable connects your Solo 2 DL to your ECU wiring. This is one of the connection cables available for the Solo 2 DL. Others are the RS232/CAN and the RPM cable. Some of the OBDII protocol channels received are RPM, vehicle speed, fuel level, and throttle position. For an extended list of protocols, please see the technical data sheet in the free downloads tab.
Solo 2 DL OBDII External Power Cable
