Motorsport Lithium Battery
Super B Andrena 12V25Ah Lithium Battery equals a lead-acid battery of 100 to 130Ah, provided the alternator’s maximum current doesn’t exceed the battery’s maximum charge current of 77A. It is a 12V lithium iron phosphate battery, delivering 25Ah (320Wh) of capacity for reliability, high performance and results. Designed in a standard rally casing, the Super B Andrena 12V25Ah Lithium Battery is specifically made for setups that have larger engines or ones that run more electronics, including those of motorcycles, off-road vehicles and cars.
Why Choose the Super B Andrena 12V25Ah Battery
As the Andrena Battery is very lightweight and compact, it can fit with ease in any vehicle and eliminates the need to constantly check on it due to its low maintenance features. The fast-charging aspect of the battery, combined with the minimal self-discharge rate, means that the battery life is long-lasting and quick to refill, ensuring that usage of the Super B Andrena 12V25Ah Lithium Battery is maximised. With lithium iron phosphate (LiFePO4) technology, combined with its waterproofness, it is the safest and most reliable battery on the market.
Lightweight Power
The Super B Andrena 12V25Ah Lithium Battery is compact in size, measuring in at 249 x 96 x 141mm and weighing 4.3kg, so it is perfect for vehicles that need a smaller power source with high energy capacity.
At only 1/3 of the size of traditional lead-acid batteries, the Super B Andrena 12V25Ah Lithium Battery not only simplifies maintenance and installation in tight engine bays, but it also improves fuel economy and performance, delivering sharper handling, quicker acceleration and less strain on suspension components.
High-Performance
The Super B Andrena 12V25Ah Lithium Battery delivers exceptional power with a stable and flat discharge curve, meaning over 80% of its capacity is usable. It supports high continuous and pulse discharge currents, making it ideal for demanding motorsport applications.
Safe & Reliable
3-Year Warranty
The Super B Andrena 12V25Ah Lithium Motorsport Battery comes with a 3-year manufacturer warranty and support from Aim Shop’s experienced technical team for your peace of mind. Super B provides batteries that have been engineered and tested against the harshest of environments to ensure high performance for years to come.
Electrical Specifications
  • Nominal Capacity: 25Ah
  • Energy: 320Wh
  • Nominal Voltage: 12.8V
  • Open Circuit Voltage: 13.2V
  • EqPb (Equals lead-acid): 100 - 130Ah
Mechanical Specifications
  • Dimensions (LxWxH): 249 x 96 x 141mm / 9.8” x 3.78” x 5.55”
  • Weight: 4.3kg / 9.5lbs
  • Case Material: PC - ABS
  • Ingress Protection: IP69
  • EAN-13: 8718531360082
  • Battery Designation: 4IFpR27/66-10
  • Charge Method: CCCV
  • Max Charge Current: 77A
  • Discharge Current Continuous: 385A
  • Discharge Pulse Current (1 sec): 1045A (42C)
Temperature Specifications
Compliance Specifications
SKU: SB-25
Guía del usuario de Super B Andrena
Guía de inicio rápido de Super B Andrena
Super B Andrena 12Ah25V Tech Sheet
Andrena 12V20Ah
Andrena 12V25Ah
Mason 12V25Ah
  • Ideal for larger single-seaters up to 2000cc using an alternator, total loss systems for shorter sprint races, FF2000, Larger hot hatches, Clio/ BMW Mini etc, Saloon and sports cars using an alternator up to 2500cc, rally cars up to 1600cc, Caterham, Westfield, historic cars up to 2000cc (Mason)
  • 27.4kg weight saving over lead batteries
  • Compact & lightweight
  • High discharge rates
  • Low self-discharge
  • Fast charging
  • 3-year warranty
  • Ideal for larger sports and saloon cars up to 3500cc, touring cars, drift cars, time attack cars, rally cars, off-road 4x4, historic cars up to 3500cc (Mason)
  • Equals lead-acid: 100 - 130Ah
  • 31.5kg weight saving over lead batteries
  • Fast charging
  • 3-year warranty
  • Ideal for larger sports and saloon cars up to 3500cc, touring cars, Drift cars, Time attack cars, Rally cars, off-road 4x4, Historic cars up to 3500cc (Mason)
  • 30.3kg weight saving over lead batteries
  • Fast charging
  • 3-year warranty
  • Dimensions: 120 x 82 x 238mm
  • Weight: 3.2kg
  • Dimensions: 249 x 96 x 141mm
  • Weight: 4.3kg
  • Dimensions: 255 x 101 x 171mm
  • Weight: 5.2kg
  • IP69
  • IP69
  • IP66
  • Andrena 12V20Ah
  • Andrena 12V25Ah
  • Mason 12V25Ah
  • Nominal Capacity: 20Ah
  • Energy: 256Wh
  • EAN-13: 8718531360051
  • Max Charge Current: 66A
* Do not charge below 0°C
  • Energy: 320Wh
  • Discharge Pulse Current (1 sec): 1045A (45C)
  • Energy: 320Wh
  • EAN-13: 8718531361775
  • Discharge Current Continuous: 260A
  • Discharge Pulse Current (1 sec): 1000A (45C)
