Compact Dash Display
The Aim GS-Dash is a compact dash display that has been designed to show data sampled by the XLog, EVO4S and EVO5 loggers.
The Aim GS-Dash integrated into the cockpit.
Why Choose the Aim GS-Dash
The compact dimensions of the GS-Dash make it particularly suitable for small cockpit installations, such as formula cars and kit cars. Manufactured in aluminium with edge-to-edge glass and metallic push buttons, the Aim GS-Dash is robust and fully waterproof.
It displays racing data from the car’s ECU, from the accelerometers, GPS and any custom sensors, and it features connectivity with the XLog, EVO4S or EVO5 with minimum effort.
Please Note: The GS-Dash is not compatible with EVO4.
GS-Dash backlight colour options
Compact Display & Customisable Pages
The GS-Dash is compact in structure and features a wide 268 x 128-pixel display. It can be backlit in one of seven available colours, and it also features an ambient light sensor that makes brightness and contrast ideal for differing light conditions.
The GS-Dash also has customisable pages showing lap times and data; you decide what data is displayed and how the pages look. Rolling time, static and predictive lap time are also available to view.
Cargar video: Delta times LED display feedback on the 5 inch display
Keyboard Operations
The GS-Dash can perform some operations via the pop-up keyboard. These include:
  • Enabling/disabling the backlight
  • Selecting the nearest track to race
  • Checking GS-Dash firmware version
  • Deleting the data stored on EVO4S & EVO5
Cargar video: Integrated shift light array interface and customisable alarms for the GS-Dash
The GS-Dash features five RGB shift lights which can be individually configured for each gear, choosing LED colour and RPM threshold values for their activation.
Alarm LEDs are managed in a very flexible way. You can choose the situation that generates the alarm, the LED behaviour (blinking frequency and colour) when the alarm appears and the conditions for switching off; a warning message can also be shown.
When your session is over, you can easily recall your sampled data using your data logger. A key summary is available at the end of each session, the best laps of the session with their times, min/max speed and min/max RPMs.
Analyse XLog and GS-Dash data with Race Studio
Analyse with Race Studio 3
When paired with an XLog or ECULog, all data logged can be displayed, and then downloaded wirelessly or via USB-C, then reviewed in Aim’s professional Race Studio 3 software.
Expand your GS-Dash with ACC3, Data Hub and sensors
Integrate the XLog, Data Hub and ACC3 to sample data coming from temperature, pressure, suspension and other sensors; you will also be able to integrate a SmartyCam 3, taking your data to the next level by incorporating synchronised video footage to overlay the data recorded by an XLog data logger onto your footage post-session with Race Studio 3, as well as the LCU-One Lambda Controller which captures air/fuel ratios and exhaust data for tuning and performance optimisation.
  • Display Resolution: 268 x 128 pixels
  • Backlight: 8 configurable RGB colours
  • Display Pages: Fully configurable
  • Body: Aluminium
  • Dimensions: 127.8 x 82 x 22.2mm
  • Weight: 380g
SKU: GS-DASH
Part Number: X55GSDASH00
Aim GS Dash Datalogger dimension diagram
GS-Dash User Guide
GS-Dash Tech Sheet
How does the Aim GS-Dash Car Racing Dash Display work?
The Aim GS-Dash is a display that connects directly to a data logger via CAN, drawing power and data through a single cable. Once set up, it displays the information collected by the logger, such as RPM, temperature and any personalised configurations. You can fully customise the display on the dash using our free Race Studio 3 software, picking which data you want to see on-screen. You can also have multiple pages, allowing you to switch through various data sets.
What devices is the Aim GS-Dash Display compatible with?
The Aim GS-Dash Display is compatible with various Aim Data Loggers, such as the XLog, ECULog, EVO4S and the EVO5. However, it is not compatible with the EVO4 model.
