This SmartyCam 3 Corsa is fully equipped and ready to take on its second life. The product is in full working order at a reduced price, and has been meticulously checked by our technicians.
The Best Motorsport Action Camera
The Aim SmartyCam 3 Corsa camera has been engineered to deliver unparalleled video performance, with GPS and ECU data for complete and comprehensive information, making it one of the best motorsport action cameras on the market.
Please Note:  The camera MUST be externally powered as the internal battery is only designed for initial configuration.
SmartyCam Corsa mounted in motorsport setup
Why Choose the Aim SmartyCam 3 Corsa
The SmartyCam 3 Corsa allows you to automatically start and stop recording via an inbuilt 3-axis accelerometer, so you can focus on driving. It has a global shutter CMOS sensor that eliminates the “wave effect” from engine vibrations, while the rugged, machined aluminium housing withstands extreme track conditions and is IP65 sealed.
Real time configurable data overlays let you personalise videos with speed, RPM, track map, gear shifts and more, pulling data from GPS, ECU, or connected Aim products, and all data is logged directly to an SD card (up to 2TB).
Charger la vidéo: SmartyCam footage in motorsport setup
All The Data You Need
From speed, RPM, and lap number, to gear shifts and much more, data can be read from all possible sources. From GPS; track map and vehicle position as well as speed, lap and split times, or from an Aim logger; RPM, throttle, engaged gear, acceleration, temperatures, pressures can be recorded as well.
Containing a full internal datalogger, all data received from the CAN bus and from the internal sensors are recorded in .mp4 files produced at the end of your test, your SD (or MSD) Card contains all the information you need for a deep data analysis.
SmartyCam 3 Corsa can automatically recognise which track you're on and begin mapping - if your track does not register, you can create your own custom track within Race Studio 3.
Using our free Race Studio 3 software, you can split sessions into individual laps for detailed comparison against your own or others’ fastest laps, and you can configure your video overlays in a virtually infinite variety of ways: add your logo and the track map, choose your graphical objects from a list of pre-determined sets or even single objects from different sets.
Charger la vidéo: Showcase of the Race Studio Software
Higher Storage Capacity
Other HD cameras often chase higher pixel counts which leads to huge file sizes without much real benefit. The SmartyCam 3 Corsa is different: it uses smart H.264 compression settings that keep the video quality you need, while keeping file sizes small. This means you can quickly download and review footage at the track for data analysis, instead of dealing with huge cinematic files that look pretty but slow you down.
Choose between three file quality levels: One hour recording = 4GB (high quality), 2GB (normal quality) or 1.5GB (lower quality).
The SD card housing on the Aim SmartyCam 3 Corsa is 100% protected from air and weathering.
SD cards sold separately.
Expand your SmartyCam 3 Corsa with an MXS display, ACC3, Data Hub and sensors
Overlay your delta, predictive, timing splits, lap data and more in Race Studio 3 when you pair the SmartyCam 3 Corsa with the Aim Solo 2 DL GPS lap timer. Expand your system further with additional sensors and expansions such as the ACC, LCU-One S, Data Hubs, sensors and more.
  • CMOS Sensor: Global shutter
  • Field Of View: 67° or 84°
  • External Power: 9-15V
  • Connectors: 1 7-pin binder 712 female, 2 5-pin binder 712 female & 1 USB-C
  • Auto Power ON/OFF: Yes
  • Dimensions: 102.2 x 63 x 46.5mm
  • Weight: 280g, battery included
Microphone Connectors On SmartyCam
SmartyCam 3 Corsa User Guide
SmartyCam 3 Corsa Tech Sheet
SmartyCam 3 Sport
SmartyCam 3 Corsa
SmartyCam 3 GP
SmartyCam 3 Dual
  • Automatic track selection
  • Auto start/stop recording
  • Custom overlays
  • Sapphire frontal glass
  • Durable & waterproof
  • Supports SD card
  • Custom overlays
  • Sapphire lens glass
  • New fast locking system
  • USB-C port for PC/laptop
  • ECU CAN Input
  • Supports SD card
  • Custom overlays
  • Compact bullet camera
  • ECU CAN input
  • Supports SD card
  • Video output streaming
  • Supports SD card
  • Built-in data logger
Dimensions:
Weight:
  • Main Unit: 320g
  • Bullet Camera: 45g
Size
Weight
  • Main Unit: 800g
  • SmartyCam 3 Sport
  • 2 or 4 Metre Cable
  • 12V Mains Charger
  • SmartyCam 3 Corsa
  • USB-C Cable
  • 12V Mains Charger
  • SmartyCam 3 GP
  • USB-C Cable
  • Bullet Camera
  • Coax Cable
  • 12V Mains Charger
  • SmartyCam 3 Dual
  • USB-C Cable
  • 2 Bullet Cameras
  • 2 Coax Cables
  • Field of View: 67° or 84°
  • Video Out: 3G-SDI
  • Body: Anodised aluminium
  • Video Output: 3G-SDI
What is the SmartyCam 3 Corsa?
The Aim SmartyCam 3 Corsa is a high-performance motorsport camera that has been specifically designed to capture high-quality recordings of your laps. With additional GPS and ECU data for more advanced and detailed information, the SmartyCam 3 Corsa is the best motorsport action camera on the market.
What are the differences between the SmartyCam 3 Corsa and the SmartyCam 3 Sport?
The SmartyCam 3 Corsa and Sport are both high-quality cameras that have been specifically designed for motorsport environments. However, the SmartyCam 3 Sport focuses on performance and versatility for motorsports like karting, club racing and motorcycle racing.
Conversely, the SmartyCam 3 Corsa is made for motorsports like touring cars and focuses on more advanced data integration and high-quality recording. The Corsa also supports CAN expansion and integrates with different Aim products to enhance data logging. For a full comparison of the SmartyCam 3 Series, take a look at the comparison tab.
Which products are compatible with the SmartyCam 3 Corsa camera?
All SmartyCams are designed to work within the Aim ecosystem, including the Solo 2 DL, MyChron 6, MX Displays (including Display Loggers), PDMs, Data Hubs, ACC3 and various sensors.
How are cameras & sensors used in racing?
Aim SmartyCam cameras automatically record track sessions with telemetry data overlays on the video. When combined with sensors, the SmartyCam 3 Corsa helps to monitor essential vehicle data to keep the vehicle running at its best and improve overall driving performance.
How do I mount the Aim SmartyCam 3 Corsa?
The Aim SmartyCam 3 Corsa has a variety of optional mounts such as a suction cup, u bolt, or roll cage bracket. All mounting options provide a stable and vibration-resistant mounting solution, ensuring maximum visibility of your laps.
Does the SmartyCam 3 Corsa come with a microphone?
Yes, the Corsa model comes with a built-in internal microphone, as well as supporting an external microphone for enhanced audio quality. The compatible 7-pin external microphone can be easily connected to the 'ECU-MIC' port at the back of the SmartyCam Corsa camera.
