Compact 5” Dash Display
The MXS Strada with road icons is one of the most widely used dash displays on roads around the world. The MXS 1.3 Strada has a compact 5" colour TFT display that offers a great visual impact. You can configure the dash to show all the information coming from the car’s ECU, analogue/digital inputs, predefined math channels and an optional GPS Module.
The MXS Strada Display is an HD digital display, designed for motorsport drivers who need essential data visibility while on the track or road. The dashboard is tailored to show real time data such as speed, RPM and temperatures, but doesn't include data logging functionalities natively.
The MXS 1.3 Strada is available with a choice of connections. Choose either the OBDII or K-Line CAN, depending on whether you want to connect to the car's ECU or OBDII port or directly to the ECU through the CAN channel.
Digital Outputs
The MXS 1.3 Strada features a 1-AMP digital output configurable to be activated/deactivated depending on the value of the analogue/digital inputs or on the impulses coming from the car’s ECU. This allows you to automatically run external systems, such as switching on/off additional lights, to activate/deactivate a cooling fan or circulation pumps when a certain event happens.
טעינת וידאו: Delta times LED display feedback on the MXS 5 inch Strada Display
טעינת וידאו: Integrated shift light array interface and customisable alarms for the MX Strada Series
Display with Road Icons
טעינת וידאו: Pre-configured dash display screens for the MX Strada Series.
Pre-Configured Pages
  • All channels
  • ECU drivers
  • Math channels
  • Display pages
  • Digital outputs
  • Alarms
  • Shift lights
  • Expansions
  • Ambient Light Sensor: Yes
  • CAN Connections: 2
  • Second CAN: Yes
  • Body: Anodised aluminium
  • Power Consumption: 400mA
  • Display: 5" TFT
  • Contrast: 600:1
  • Weight: 480g
SKU: MXS-S-I
MXS Strada User Guide
MXS Strada Tech Sheet
What does the MXS Strada do?
The Aim MXS Strada is a digital dash display that can be configured to show real time information from the car's ECU, analogue/digital inputs, predefined math channels and an optional GPS Module. It provides crucial information like speed, RPM, water temperature, and oil pressure on a high-contrast TFT screen.
What is a TFT dash display?
A TFT (thin-film transistor) dash display is a customisable digital screen that uses thin-film transistors to control individual pixels, resulting in vibrant colours, sharp images and high contrast, making it a common feature in many modern road cars.
What size is the MXS display?
The MXS Strada with road icons is best suited to performance street cars, modified road cars and competition cars that also need to be road-legal to drive to and from a racetrack.
The main difference between the MXS logger and the MXS Strada display is that the logger version has a built-in data logger. However, a Strada Logger can be purchased for the MXS Strada, which records data to an SD card. The MXS logger also has 2 digital outputs, whereas the Strada only has 1. For a full comparison of the MX Strada Series, take a look at the comparison tab.
How do you switch between pages on the Aim MXS Strada?
To switch pages on the Aim MXS Strada, first open our free Race Studio 3 software and then select the Page Configuration to customise each page. After choosing your selections, save your configurations and press the ">>" push button on the side of the device to switch between your pages.
How do I connect my MXS Strada to my car’s engine control unit (ECU)?
How do I connect my MXS Strada to the car’s OBDII connector?
Use a dedicated OBDII wiring harness and configure the MXS Strada with Race Studio 3. The process involves a physical connection followed by software setup to identify your car's specific ECU protocol. More information can be found here.
  • 10” TFT display
  • 10 shift light RGB LEDs
  • CAN output
  • 6 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • 7" TFT display
  • CAN output
  • 8 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • 6" TFT display
  • CAN output
  • 5 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • 5" TFT display
  • CAN output
  • 6 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • Weight: 1,100g
  • Weight: 950g
  • Weight: 590g
  • Weight: 480g
  • IP67
  • MXT Strada Dash
  • 14-Pin Standard Wiring
  • MXG Strada Dash
  • MXP Strada Dash
  • MXS Strada Dash
  • Second CAN: Yes
  • Body: Anodised Aluminium
  • Power Consumption: 450mA
  • Second CAN: Yes
  • Second CAN: Yes
  • Second CAN: Yes
  • Display: 10" TFT
  • Contrast: 1,100:1
  • Display: 7" TFT
  • Contrast: 1000:1
  • Display: 6" TFT
  • Display: 5" TFT
