Next Generation Motorsport Action Camera
The Aim SmartyCam 4 Corsa has been purpose-built for motorsport, combining exceptional video quality with advanced data integration to give drivers and teams the information they need to improve performance. Building on the success of the SmartyCam 3 Corsa, the latest generation introduces major upgrades in image quality, connectivity, and usability, making it one of the most capable motorsport cameras available today.
Please Note:  The camera MUST be externally powered as the internal battery is only intended for initial setup and configuration.
Ladda video: Footage showing SmartyCam 4 Corsa 12MP Sony CMOS
Why Choose the Aim SmartyCam 4 Corsa?
Designed specifically for racing environments, the SmartyCam 4 Corsa automatically starts and stops recording using its integrated 3-axis accelerometer, allowing you to stay focused on driving.
At the heart of the camera is a Sony 12-megapixel CMOS sensor, delivering significantly improved image quality with sharper detail, better colour accuracy, and stronger low-light performance. An integrated LSI image stabiliser helps reduce vibration, optical distortion, and horizon movement, producing smooth, stable footage even in demanding track conditions.
High-Quality Video with Real Performance Data
SmartyCam 4 Corsa does more than capture footage; it overlays the data that matters most. Real time configurable overlays allow you to display:
  • Speed
  • RPM
  • Gear position
  • Lap and split times
  • Track map
  • Throttle position
  • Temperatures and pressures
  • Acceleration data
  • Warning alerts such as oil pressure or battery voltage
Every element can be customised with different styles, graphics, and screen positions, giving you complete control over how your data appears.
12MP Sony CMOS Sensor in camera lens
The SmartyCam 4 Corsa camera takes video quality to the next level, featuring a cutting-edge 12MP Sony CMOS sensor paired with a powerful dedicated ISP processing chip.
Enjoy exceptionally sharp footage, richer and more accurate colours, and outstanding performance in every lighting condition, capturing every detail with professional-grade precision.
Aim SmartyCam 4 Corsa camera mounted to a vehicle in an extreme motorsport environment
Designed for the Extreme
Guaranteeing you great resistance against the extreme conditions of racing and against the most adverse weather.
SmartyCam 4 cameras are IP65 waterproof and are made with CNC billet aluminium with sapphire frontal glass for complete protection.
Access Data from Multiple Sources
The SmartyCam 4 Corsa gathers information from a wide range of inputs for complete session analysis.
  • From GPS: Track map and vehicle position, speed, lap times and split times.
  • From Aim loggers connected to your ECU: RPM, throttle position, engaged gear, temperatures, pressures, acceleration and additional external sensors.
This creates a fully integrated video and telemetry system for both track day drivers and professional race teams.
Aim SmartyCam 4 Corsa with USB-C memory card
Smarter Setup & Faster Connectivity
The latest generation introduces a USB-C port for quicker configuration, data downloads, and external storage connectivity.
A new real time companion app also provides an intuitive user interface for camera setup and adjustments, making it easier than ever to configure overlays, settings, and recording options without removing the camera from the vehicle.
Ladda video: A video of the SmartyCam 4 automatically recognising which track you’re on and beginning mapping
Automatic Track Recognition & Lap Analysis
The SmartyCam 4 Corsa can automatically recognise which track you’re on and begin mapping - if a track is not listed, custom tracks can be created using Aim's Race Studio software.
After each session, footage can be split into individual laps for detailed review and direct comparison against previous sessions, teammates, or benchmark laps.
Efficient File Sizes, Maximum Usability
Unlike conventional action cameras that prioritise oversized files, the SmartyCam 4 Corsa focuses on motorsport usability. Efficient compression keeps file sizes manageable while preserving the quality needed for detailed review, allowing faster downloads and quicker analysis between sessions.
Race Studio 3 App being used for Aim SmartyCam 4 Corsa
Brand-New Race Studio 3 App
With the dedicated Race Studio 3 app, all camera settings including framing, frame rate, image flip and more, can be easily adjusted right from your smartphone, providing precise control for any track or condition.
Data analysis remains one of the most effective ways to improve lap times and vehicle reliability. By combining onboard video with telemetry, the SmartyCam 4 Corsa helps you identify faster and slower sectors, braking and throttle points, gear selection errors, chassis balance issues, engine warnings or pressure drops, and consistency across multiple laps.
Aim SmartyCam 4 Corsa camera expansions with Aim devices
Overlay your delta, predictive, timing splits, lap data and more in Race Studio 3 when you pair the SmartyCam 4 Corsa with the Aim Solo 2 DL GPS lap timer. Expand your system further with additional sensors and expansions such as the ACC, LCU-One S, Data Hubs, sensors and more. Please see the connections tab for connection examples.
  • CMOS Sensor: Sony 12 MP CMOS
  • External Power: 9-15V
  • Streaming: Via USB or Wi-Fi
  • Auto Power ON/OFF: Yes
  • Body: Anodised Aluminium
SmartyCam 4 Corsa Diagram
SmartyCam 4 Corsa Pinout
  • SmartyCam 4 Corsa front view
    SmartyCam 4 Corsa
  • MyChron 6 Mini USB Drive 16GB - AimShop.com
    USB-C Memory Card 64GB
  • AiM Solo 2 and Solo 2 DL mains charger with UK plug power cable for lap timer accessories
    12V Mains Charger
  • Cables icon
    CAN-kabel
  • MyChron 6 USB 2.0 A-Type C-Type 100cm Cable - AimShop.com
    USB Type-A to Type-C Cable
SmartyCam 4 Corsa Tech Sheet
What is the SmartyCam 4 Corsa?
The Aim SmartyCam 4 Corsa is a high-performance motorsport camera that has been specifically designed to capture high-quality recordings of your laps. With additional GPS and ECU data for more advanced and detailed information, the SmartyCam 4 Corsa is the best motorsport action camera on the market.
Which products are compatible with the SmartyCam 4 Corsa camera?
All SmartyCams are designed to work within the Aim ecosystem, including the Solo 2 DL, MyChron 6, MX Displays (including Display Loggers), PDMs, Data Hubs, ACC3 and various sensors.
How are cameras & sensors used in racing?
Aim SmartyCam cameras automatically record track sessions with telemetry data overlays on the video. When combined with sensors, the SmartyCam 4 Corsa helps to monitor essential vehicle data to keep the vehicle running at its best and improve overall driving performance.
How do I mount the Aim SmartyCam 4 Corsa?
The Aim SmartyCam 4 Corsa has a variety of optional mounts such as a suction cup, u bolt, or roll cage bracket. All mounting options provide a stable and vibration-resistant mounting solution, ensuring maximum visibility of your laps.
SmartyCam 4 Corsa
SmartyCam 3 Sport
SmartyCam 3 GP
SmartyCam 3 Dual
  • Automatic track selection
  • Full HD images 1080p, 30-60 fps
  • Auto start/stop recording
  • Custom overlays
  • Sapphire lens glass
  • 12 MP Sony CMOS sensor with a Sony LSI stabiliser
  • USB-C port for PC/laptop
  • ECU CAN Input
  • Low-Distortion Lens
  • Dual microphones
  • Internal LiPo battery
  • Custom overlays
  • Sapphire frontal glass
  • Durable & waterproof
  • Supports SD card
  • Custom overlays
  • Compact bullet camera
  • ECU CAN input
  • Supports SD card
  • Video output streaming
  • Supports SD card
  • Built-in data logger
Dimensions:
Weight:
  • Main Unit: 320g
  • Bullet Camera: 45g
Size
Weight
  • Main Unit: 800g
  • SmartyCam 4 Corsa
  • USB Type-A to Type-C Cable
  • 2 or 4 Metre Cable
  • 12V Mains Charger
  • USB-C Memory Card 64GB
  • SmartyCam 3 Sport
  • 12V Mains Charger
  • SmartyCam 3 GP
  • USB-C Cable
  • Bullet Camera
  • Coax Cable
  • 12V Mains Charger
  • SmartyCam 3 Dual
  • USB-C Cable
  • 2 Bullet Cameras
  • 2 Coax Cables
  • CMOS Sensor: Sony 12MP CMOS
  • Body: Anodised aluminium
  • CMOS Sensor: Global shutter
  • Field of View: 67° or 84°
  • Video Out: 3G-SDI
  • Video Output: 3G-SDI
