MXS Strada Motorcycle Dash
The MXS Strada with race icons is one of the most widely used dash displays on tracks around the world. The MXS 1.3 Strada has a compact 5" colour TFT display that offers a great visual impact. You can configure the dash to show all the information coming from the motorcycle’s ECU, analogue/digital inputs, predefined math channels and an optional GPS Module.
The MXS Strada 5" Display integrated into a motorcycle setup.
The MXS Strada Display is an HD digital display, designed for motorcycle riders who need essential data visibility while on the track or road. The dashboard is tailored to show real time data such as speed, RPM and temperatures, but doesn't include data logging functionalities natively.
The MXS 1.3 Strada has a choice of ECU connections. Choose between the OBDII or K-Line CAN. Depending on whether you want to connect to the motorcycle's ECU using the OBDII port or directly to the ECU through the CAN channel.
Connecting the MXS 1.3 Strada dash to your motorcycle's ECU is simple; you can sample and display dozens of channels. This is usually the quickest and easiest setup, needing only 2 cable connections to the ECU instead of multiple connections to analogue sensors.
The sampled data depends on the actual ECU, but will typically include RPM, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel ratio). The list of available ECU drivers is over 1,000 and is constantly being updated and upgraded.
Digital Outputs
The MXS 1.3 Strada features a 1-AMP digital output configurable to be activated/deactivated depending on the value of the analogue/digital inputs or on the impulses coming from the motorcycle's ECU. This allows you to automatically run external systems, such as switching on/off additional lights, to activate/deactivate a cooling fan or circulation pumps when a certain event happens.
Indlæs video: Delta times LED display feedback on the MXS 5 inch Strada Display
Indlæs video: Integrated shift light array interface and customisable alarms for the MX Strada Series
Display with Race Icons
The MXS 1.3 Strada has a 5" TFT high contrast colour display. The visual quality is optimised by the ambient light sensor, which keeps the backlight at the best brightness levels. Race icons allow you to apply conditions to the LED icons.
Indlæs video: Pre-configured dash display screens for the MX Strada Series.
Pre-Configured Pages
Connecting an MX Strada Logger to your display enables it to log your data. With Race Studio 3, available to download on desktop or our mobile app, you can create, modify, delete, import and export configurations of:
  • All channels
  • ECU drivers
  • Math channels
  • Display pages
  • Digital outputs
  • Alarms
  • Shift lights
  • Expansions
MX Strada Series Expansions list; SmartyCam 3 GP, ACC3, Data Hub, GPS, and more.
Please Note: A 14-pin harness comes standard in the kit. Should you need more data, you can add our 23-pin harness as an optional extra.
  • Ambient Light Sensor: Yes
  • CAN Connections: 2
  • Second CAN: Yes
  • Body: Anodised aluminium
  • Power Consumption: 400mA
  • Display: 5" TFT
  • Contrast: 600:1
  • Weight: 480g
SKU: MXS-S
MXS Strada User Guide
MXS Strada Tech Sheet
What does the MXS Strada do?
The Aim MXS Strada is a digital dash display that can be configured to show real time information from the motorcycle's ECU, analogue/digital inputs, predefined math channels and an optional GPS Module. It provides crucial information like speed, RPM, water temperature, and oil pressure on a high-contrast TFT screen.
What is a TFT dash display?
A TFT (thin-film transistor) dash display is a customisable digital screen that uses thin-film transistors to control individual pixels, resulting in vibrant colours, sharp images and high contrast, making it a common feature in many modern racing motorcycles.
What size is the MXS display?
The MXS Strada comes with 6 customisable RGB LEDs, which are determined by inputs from the motorcycle's ECU or other sensors. The MXS Strada with race icons can be configured with alarms for gear position, lap time improvement, throttle position, low fuel, low oil pressure, low oil level and other customised alarms that have been set.
What are the best applications for the MXS Strada with race icons?
The MXS Strada with race icons is best suited to motorcycles that are used primarily for track day racing purposes.
The main difference between the MXS logger and the MXS Strada display is that the logger version has a built-in data logger. However, a Strada Logger can be purchased for the MXS Strada, which records data to an SD card. The MXS logger also has 2 digital outputs, whereas the Strada only has 1.
How do I connect my MXS Strada to my motorcycle's engine control unit (ECU)?
How do I connect my MXS Strada to the motorcycle's OBDII connector?
Use a dedicated OBDII wiring harness and configure the MXS Strada with Race Studio 3. The process involves a physical connection followed by software setup to identify your motorcycle's specific ECU protocol. More information can be found here.
MXS Strada
MXP Strada
  • 5" TFT display
  • 10 shift light RGB LEDs
  • CAN output
  • 6 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • 6" TFT display
  • CAN output
  • 5 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • Weight: 480g
  • Weight: 590g
  • MXS Strada Dash
  • 14-Pin Standard Wiring
  • MXP Strada Dash
  • Second CAN: Yes
  • Body: Anodised Aluminium
  • Second CAN: Yes
  • Display: 5" TFT
  • Display: 6" TFT
