Advanced Powerboat Dash Logger
The MXG 1.3 powerboat dash logger has a 7" TFT digital display, which has been designed to acquire and display data coming from the ECU. It is an ideal choice for sailors who want valuable data at their fingertips.
The MXG 7" Powerboat Dash Display & Data Logger in a boat cockpit
Why Choose the MXG Powerboat Display & Data Logger
The Aim MXG 1.3 is a compact but powerful motorsport display and data logger. It offers real time data on its 7” TFT screen, has customisable display layouts, lap timing capabilities thanks to the GPS09 Module (included in the kit), and is compatible with a range of Aim devices and expansions for the ultimate setup.
A Range of Data Sources
The MXG digital dash is designed to collect and display data from the powerboat's ECU, the internal accelerometer & gyro, the included GPS09 Module, analogue & digital inputs, and predefined math channels. You can also expand its capabilities by adding up to 8 modules to enhance performance and data acquisition.
Connecting the MXG 1.3 dash to the ECU is simple. You can sample dozens of channels straight from the boat’s ECU (compatible with over 1,000 different ECUs), requiring only a cable connection to the ECU instead of multiple connections and analogue sensors.
Cargar video: Delta times LED display feedback on the MXG 7 inch data logger for powerboat
Cargar video: Integrated shift light array interface and customisable alarms for the MX Series Data Logger for powerboat
The MXG display logger also comes with 8 RGB LEDs, allowing you to customise colours, alarm types (solid or flashing), flashing frequency and accompanying text messages. Alarm priorities can be set to suit your specific requirements.
Cargar video: Pre-configured dash display screens for the MX Logger Series.
Pre-Configured Pages
With its high-contrast 7” TFT display, you can configure pages to suit your needs. The digital display also allows you to easily navigate through the pages to choose from a variety of styles, data types and measurement units. An ambient light sensor adjusts the backlight for optimal brightness, ensuring clear visibility in all lighting conditions.
The system also supports 2 analogue camera inputs for a mirror camera function, activated by a push button or event. The camera is sold separately.
GPS Module
The included GPS09 module, connected to the MXG dash logger via CAN, simplifies lap time calculation and course position analysis. With over 4,000 courses worldwide already stored, including the start and finish line coordinates, you’ll have no trouble monitoring your position and lap times when you’re sailing.
As soon as the MXG is turned on, the GPS module will locate its position, identify course coordinates and start immediately sampling lap and split time. If the course is not in the database, you can easily add the start/finish line coordinates to the MXG using our Race Studio 3 software.
Note: The GPS Module is available with cable lengths of 50cm, 1.3m, 2m or 4m, or a roof version with 2m or 4m length cables.
  • All channels
  • ECU drivers
  • Math channels
  • Display pages
  • Digital outputs
  • Alarms
  • Shift lights
  • Expansions
The LCU-One S allows you to perfectly tune the carburetion of your engine to keep it at its best and improve the engine's performance. Alongside the Analogue CAN Converter, you can choose among 5 different split harnesses. Up to 4 thermocouples or 4 analogue channels 0-5V/0-12V are available.
The SmartyCam series also connects to record synchronised video and telemetry ready for analysis in Race Studio 3.
  • Ambient Light Sensor: Yes
  • CAN Connections: 2
  • Second CAN: Yes
  • Body: Anodised aluminium
  • Power Consumption: 400mA
  • Display: 7" TFT
  • Contrast: 1,000:1
  • Weight: 950g
SKU: MXG-S
Aim MXG Datalogger Display dimension diagram
MX User Guide
MXG Tech Sheet
MXS Dash Display Logger
MXG Dash Display Logger
  • 5" TFT display
  • 10 shift light RGB LEDs
  • 3 CAN connections
  • GPS Module
  • 6 alarm RGB LEDs
  • 8 analogue inputs
  • 2 digital outputs
  • Wi-Fi connectivity
  • Integrated shift array
  • 7" TFT display
  • 3 CAN connections
  • GPS Module
  • 8 alarm RGB LEDs
  • 8 analogue inputs
  • 2 digital outputs
  • Weight: 530g
  • Weight: 950g
  • IP67
  • IP67
  • MXS Dash Logger
  • 37-Pin Standard Harness
  • GPS Module with Cable
  • MXG Dash Logger
  • CAN Connections: 3
  • Digital Outputs: 2 (1A max)
  • Second CAN: Yes
  • Wi-Fi Connection: Yes
  • Internal Memory: 4GB
  • Body: Anodised Aluminium
  • Second CAN: Yes
  • Display: 5" TFT
  • Display: 7" TFT
  • Contrast: 1000:1
