SB-E-210
Super B Nomia 12V210AH Batería de tracción de litio
Power For Performance
Engineered by Super B Energy, the Nomia 12V210Ah Battery delivers reliable lithium power with advanced safety, monitoring and thermal performance. Its advanced technology and smart software make this lithium battery a robust, low-maintenance, high-efficiency, safe and user-friendly energy storage solution, offering significant weight and space savings compared to traditional lead-acid batteries.
Super B Nomia 12V210Ah Intended Use
The Nomia 12V210Ah Lithium Battery is a traction battery designed for renewable energy storage in 12V power systems, supporting use across commercial, electric and recreational vehicles, leisure and commercial vessels and off-grid power applications.
Please Note: This battery is not suitable for use as a starter battery. Up to 4 batteries can be connected in series or in parallel to increase the total capacity up to 840Ah. When using more than 4 batteries in series or parallel, always consult Super B.
Integrated BMS
The Super B Nomia 12V210Ah Traction Battery incorporates a battery management system (BMS) to ensure a high level of safety during use. The BMS provides real time protection against overcharging, overheating, short-circuiting and imbalance, contributing to its long cycle life of over 3,500 cycles at 100% depth of discharge—ensuring maximum longevity and performance in every charge. The integrated BMS also provides adaptive cell balancing.
Safe & Reliable
Due to its LiFePO4 prismatic cell technology, which is renowned for its exceptional safety, long cycle life, high energy density and integrated BMS system, the Super B Nomia Battery is amongst the safest lithium technologies on the market. As well as the technology, the Nomia Batteries' robust casing is made from glass fibre reinforced plastic (GFRP). These features make the battery a robust, low-maintenance, highly efficient, safe and user-friendly energy storage solution, offering significant weight and space savings compared to traditional lead-acid batteries.
High-Performance
Despite its strong output, the battery remains compact and lightweight at just 417 x 227 x 314mm and 23kg, making it ideal for space-sensitive applications. The Nomia Battery also supports fast charging up to 210A, delivers high discharge currents and has a low self-discharge rate under 3% per month, ensuring that the battery retains its charge, even when not in use—ideal for seasonal applications.
In addition to its energy density, the Super B Nomia 12V210Ah Lithium Traction Battery is also known for its high level of efficiency. Unlike traditional lead-acid batteries, lithium batteries can deliver power consistently over their entire discharge cycle, without suffering from the voltage drop-off that can occur with other types of batteries. Overall, the Nomia Battery offers a reliable, low-maintenance power solution for a variety of setups.
3-Year Warranty
The Super B Nomia 12V210Ah Lithium Traction Battery comes with a 3-year manufacturer warranty and support from Aim Shop’s experienced technical team for your peace of mind. Whether you're building a custom energy setup or upgrading your vehicle's power system, Super B provides batteries that have been engineered and tested against the harshest of environments to ensure high-performance for years to come.
Testimonials
Trusted by adventurers and sailors worldwide, Super B Energy Batteries are renowned for their reliability, compact size and seamless integration with modern systems. Take a look at some of the testimonials from people who have used Super B for their own projects.
Feel The Breeze
"We have 8 lithium iron phosphate batteries (LiFePO4) at the core of our sailing yacht, a massive upgrade from the old lead-acid. The simplicity of installation, quality, and durability made this a no-brainer!" - Feel The Breeze
Stepsover World Tour
"Lithium batteries are the best solution for an overland truck like ours. Our truck is equipped with a useful domotic system that controls everything inside the truck, from the ventilation system all the way to the water pressure inside the plumbing system. This is really useful in order to prevent damage on the road and to manage every function of the interior with just a click on our tablet. We successfully integrated the new Super B lithium batteries in our truck and now we really feel more independent." - Stepsover World Tour
Sailing Fair Isle
"These batteries are a game-changer for living off grid, and we know, from talking to our fellow cruisers, that we are not the only ones making this change to lithium. Super B are the best in the business. As we continue our journey around the world, we feel safe in the knowledge that these may be the last set of batteries we ever need to install." - Sailing Fair Isle
How do you download the "Be In Charge" software & app?
Super B provides a Be In Charge Software tool, which can be used to read out the internal BMS system. The software uses a CAN to USB converter to connect to the communication interface. The software is capable of reading out the actual status, like battery/cell voltages and temperature, but also statistical information. Be In Charge software can also be used to update the installed firmware of the Li-ion battery. The Be In Charge software and hardware are not part of the Li-ion battery scope of delivery. Super B also provides a Be In Charge App for mobile devices such as Android and iOS. The app can be found in the Google Play Store or Apple App Store.
How do you install the Nomia Battery in parallel to increase capacity?
To increase the system’s capacity, place the batteries in parallel in the same orientation. Place the aluminium connection tab over the plus terminal of the first and second batteries, then secure it with the spring washers and M8 bolts. Repeat the process for the other batteries. Place the protective caps over the terminals to avoid any short circuits. Repeat the same process on the minus terminals.
Connect the plus terminal of the first battery in the series and the minus terminal of the last battery to the corresponding cables on the battery interface box. Now connect the CAN cables in the correct position at the top of the batteries. Place the CAN terminator in the open port of the first battery. The remaining open terminal will connect to the battery interface box.
Note: When installing batteries in parallel, always use batteries of the same brand, type, age, capacity and state of charge.
How do you install the Nomia Battery in a series configuration?
To increase the system’s voltage, place the batteries in parallel in alternating positions. Place the aluminium connection tab over the minus terminal and the plus terminal of the first and second batteries, then secure it with the spring washers and M8 bolts. Repeat the process for the other batteries. Place the protective caps over the terminals to avoid any short circuits. Repeat the same process on the remaining batteries.
Now connect the CAN cables in the correct position at the top of the batteries. Place the CAN terminator in the open port of the first battery. The remaining open terminal will connect to the battery interface box. The plus terminal of the first battery and the minus terminal of the last battery in the series should be connected to the corresponding cables on the battery interface box.
Note: When installing batteries in series, always use batteries of the same brand, type, age, capacity and state of charge.
| Specs |
Nomia 12V210Ah
Nomia 12V340Ah
Nomada 12V105Ah
Epsilon 12V150Ah
Epsilon 12V100Ah
