Yamaha Plug & Play AIM Taipan y Motocross ECU Kit
Choose Accessories
Aim Taipan Y ECU For Yamaha Bikes
The Aim Taipan Y ECU is the latest plug & play engine control unit, designed exclusively for plug & play installation for Yamaha YZ250F 2019-2023 and YZ450F 2019-2022 motocross bikes. Engineered with cutting-edge 32-bit technology, it offers unmatched precision, delivering improved performance without compromising reliability. With advanced fuel mapping and ignition strategies, the Taipan Y ECU provides superior control over your engine's behaviour for optimised power delivery and throttle response.
Why Choose the Taipan Y ECU
The Aim Taipan Y ECU is designed to give riders complete control over their motocross bike’s performance. With highly accurate ignition timing and fuel injection control, the Taipan Y ECU ensures the smoothest power delivery, maximising acceleration and traction in all conditions.
Whether you're on the track or the trails, the Taipan Y ECU provides a fully customisable racing experience tailored to your riding style.
Taipan Y ECU Connections
The Taipan Y ECU has 4 connectors:
- Main Connector: Compatible with most off-road bikes.
- CAN Connector: Connects to the Handlebar Switch 2 and data logger.
- 2nd CAN Connector: Connects to the UC Bridge to communicate with the PC.
- 3rd Connector: Connects to spare analogue inputs and a possible second injector.
Handlebar Switch 2
You can choose from up to five selectable maps with the Handlebar Switch 2.
The Taipan can manage up to five maps that can be selected both by OEM switches (Yamaha) or even more easily by the Aim Handlebar Switch 2, which is included in the motocross ECU kit.
HBS2 is the compact, high-performance, and built tough Handlebar Switch. If you're looking for a highly flexible and ergonomic switch, the Aim HBS2 offers a great solution with 4 push buttons and 11 integrated LEDs.
- Map Management
- Fuel Trim
- Traction Control Management
- Launch Control Management
- Buttons Setting Memorisation
HBS2 also allows the management of quick shifting on factory-equipped bikes.
Integrate FREE SPARK Software
SPARK is the intuitive software that lets you control, customise, and fine-tune your bike’s performance.
From map management to traction control, SPARK puts advanced tuning at your fingertips.
Thanks to the UC Bridge, designed to integrate Aim ECUs with the software, users can efficiently manage configurations, settings, and engine maps.
UC Bridge License Types
The UC Bridge included in the motocross ECU kit is available with a User License. The User License is designed for riders and enthusiasts who want an easy and reliable way to manage their ECU. It allows you to:
- Receive and install maps from your tuner: Flash updated or custom maps directly into the ECU.
- Monitor ECU status: View exceptions, errors, or problems logged by the Taipan system directly within the software.
- Adjust fuel injection: Apply pre-configured fuel injection corrections across different RPM ranges for smoother performance.
Smoothing Algorithm
By selecting at least three contiguous cells and right-clicking, a context menu appears. Choosing ‘Smoothing’ from the menu applies the smoothing algorithm, which is also reflected in the 2D view.
3D Visualisation
3D visualisation mode complements the 2D view. The 3D graph supports rotation, zooming, and panning, with controls detailed in the tab’s legend.
TPS Sensor Calibration Gauge
TPS Sensor Calibration Gauge provide a clearer and more intuitive visualisation of the TPS signal voltage.
Download the FREE SPARK App
SPARK is now available as a mobile app for both Android and iOS, with seamless Bluetooth connectivity to your bike.
Connect your smartphone to the Taipan and Yamaha ECU in two ways:
- Via the CAN-BT Module, for instant access to key engine data and real-time telemetry.
- Using the XLog, if you want to collect data while driving as well.
The Taipan ECU works seamlessly with Aim’s ecosystem of devices.
- CAN-BT Module: The CAN-BT Module grants instant access to key engine data from your Taipan ECU. Install the SPARK App on your smartphone for a streamlined, data-driven interface for real-time monitoring of live engine parameters.
- SmartyCam: Overlay logged data directly onto video for detailed driver analysis.
- Data Hub: Split EXP ports to connect multiple expansions such as the Solo 2 lap timer, UC Bridge, Handlebar Switch or additional converters.
Taipan Y Control Unit
Taipan UC Bridge
HBS2
Videos
| Specs |
Taipan Y
Taipan Y V2
Taipan K
Taipan
