This SW4 270 Formula Steering Wheel is brand-new and unused, but available at a reduced price due to limited stock and no future production. The product is in full working order at a reduced price, and has been meticulously checked by our technicians.
Data Logging Steering Wheel
The Aim Formula Steering Wheel 4 270 is amongst our most advanced motorsport steering wheels to date. It has an internal data logger with complete configuration, removable grips, rotary switches and a long list of fully compatible ECU and CAN connectivity options.
Why Choose the Aim 270 Steering Wheel
The Aim Formula Steering Wheel 270 has been specifically designed for professional motorsport applications. The internal data logger is fully configurable and has been developed to acquire and display data from the ECU, with over 1,000 fully compatible ECU protocols.
Our Formula Steering Wheels come in a range of sizes (270, 280, GT320 & GT350). The compact 270 and 280 versions are the ideal choice for single-seaters or sports prototypes where cockpit space is at a premium.
The Aim SW4 270 Formula Steering Wheel is also fully compatible with our PDM32 via CAN communication.
Connecting the Aim 270 Formula Steering Wheel to your ECU is straightforward. You can choose between an Aim Harness or craft your own harness using the existing Deutsch cable connected to the module to sample dozens of channels directly from the ECU using a single connection, rather than installing multiple analogue sensors.
The data sampled depends on the ECU in use, but typically includes RPM, engine load, throttle position (TPS), oil, air, and water temperatures, oil pressure, battery voltage, speed, gear, and lambda values (air/fuel ratio). The list of available ECU drivers is constantly updated and upgraded, and includes over 1,000 different ECUs.
With CAN output, you can send messages directly to an existing CAN network, enabling extended integration with other vehicle systems.
Display & Push Buttons
The Aim Formula Steering Wheel 4 270 is equipped with a high-contrast 4.3" TFT display, fully configurable and sunlight viewable. With 8 shift lights, 4 RGB alarm LEDs and an integrated ambient light sensor, the steering wheel delivers clear, precise, and reliable information directly to the driver at all times.
The Formula Steering Wheel 4 270 features 10 push buttons and 3 rotary switches, all backlit with RGB LEDs. It also includes removable grips, rotary switches, and a wide range of ECU and CAN connectivity options.
Flexible Alarms
The Aim SW4 270 Formula Steering Wheel offers 8 configurable shift light RGB LEDs and 4 configurable alarm RGB LEDs. You can define conditions, colours, priorities, and flashing frequencies, as well as display accompanying text messages when required.
The advanced multi-colour RGB shift lights can be fully customised, with the option to define different shift patterns for each gear.
Optional Extras
  • GPS Module: Connected via CAN, the GPS Module makes lap timing and track position analysis easy.
  • Clutch Paddles: Left/right clutch paddles can be added from the accessories at the top of the page to suit your driving style.
  • Other Expansions: Expand your system with a range of additional Aim devices, including the TC Hub, Lambda Controller, SmartyCam, RIO, GS-Dash, and more.
  • CAN Connections: 3
  • ECU Connection: CAN
  • ECU Compatibility: 1,000+ industry-leading ECUs
  • Shift Lights: 8 configurable RGB LEDs
  • Ambient Light Sensor: Yes
  • Expansion CAN Connection: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam, RIO Module, GS-Dash, Memory Module
  • Connectors: 1 Deutsch Autosport 22-pin male connector
  • Power Consumption: 500mA
  • Internal Memory: 4GB
  • Push Buttons: 10 push buttons & 3 rotary switches (all with RGB backlights)
  • Display: 4.3" TFT
  • Contrast: 800:1
  • Dimensions: 270 x 183.5 x 42.6mm
  • Weight: 2,400g
SKU: FSW4
SW4 Karta techniczna
SW4 270 (MY26) Formula Steering Wheel
  • CAN Connection
  • ECU Connection
  • Data Logging
  • Rotary Switches
  • Removable Handle Grips
  • Compact Display
  • CAN Connection
  • ECU Connection
  • Data Logging
  • Rotary Switches
  • Compact Display
  • CAN Connection
  • ECU Connection
  • Data Logging
  • Rotary Switches
  • Compact Display
  • Dimensions: 270 x 189.5 x 38.2mm
  • Weight: 1,500g
  • Weight: 2,400g
  • GT320 Dimensions: 320 x 183.5 x 42.5mm
  • GT350 Dimensions: 350 x 183.5 x 42.5mm
  • Weight: 2,600g
  • Chosen 270 Steering Wheel
  • Paddle Shifters
  • Standard Push-Button Kit
  • USB A – USB C Cable
  • 280 Steering Wheel
  • Chosen GT32 or GT350 Steering Wheel
  • ECU Compatibility: 2,000+ industry-leading ECUs
  • Expansion CAN Connection: GPS Module, LCU Series, ACC3, SmartyCam Series, RIO02, Shift Light Module, Memory Module
  • Connectors: 1 Autosport 22-pin male connector (coiled cable only) or none/free wires (quick release only) + 1 USB-C connector
  • Push Buttons: 10 push buttons & 0/1/3 rotary switches (all with RGB backlights)
  • Body: Carbon fibre-reinforced resin and forged metal
  • Display: 4.3" TFT
  • Contrast: 800:1
  • Brightness: 800 cd/m2
  • Display: 4.3" TFT
  • Contrast: 800:1
  • Display: 5" TFT
  • Contrast: 800:1
What is the Aim SW4 Formula Steering Wheel collection?
The Aim Formula SW4 collection is a range of high-performance steering wheels that are designed for single-seater motorsports. They are made to be versatile and compatible with many different racing applications and include a range of key features.
The Aim SW4 range comes in multiple sizes and has a memory of 4GB. It allows for real time data to be shown, making it easy for drivers to see where they are and to make changes based on it. You can also expand your system with GPS modules and the SmartyCam 3 through its CAN connectivity. This steering wheel is the perfect product for racers looking to upgrade their driving and data logging capabilities.
Are SW4 Formula Steering Wheels compatible with Aim devices & data logging systems?
Aim SW4 Steering Wheels are compatible with other Aim devices and data logging systems, such as the ACC3 Analogue CAN Converter, SmartyCam Cameras and various sensors. This allows for a more detailed and advanced data collection and analysis, making it a very versatile product for different motorsport applications.
What sizes do the Aim SW4 Steering Wheels come in?
The Aim SW4 Steering Wheel range is available in 4 sizes (270, 280, 320 and 350mm) for different racing applications and cockpit space available. Please see our SW4 guide for more information on which sizes are best-suited to your setup.
How do you install a Formula Steering Wheel in a cockpit?
Regardless of which steering wheel you are most interested in, connecting the Formula 4 Steering Wheel to the vehicle’s ECU is extremely easy. Start by securely mounting the wheel to your vehicle. Once the wheel is in place, you can then connect it to the ECU using the Deutsch connector harness.
After the wheel is in place and connected, Race Studio 3 software can be used to customise display pages, alarms and shift light settings according to your preferences. Please test the setup thoroughly to ensure that all functions are working correctly.
