This MXS Strada Light is fully equipped and ready to take on its second life. The product is in full working order at a reduced price, and has been meticulously checked by our technicians.
Compact Motorsport Display
The MXS Strada with race icons is one of the most widely used dash displays on tracks around the world. The Strada ‘Light’ version has been created as a more accessible product for people who will use fewer analogue inputs and just need a CAN connection for their ECU.
The MXS Strada Light 5" Display integrated into a car dashboard on a racetrack
Why Choose the MXS 1.3 Strada Light Display
Whilst being very similar to the MXS Strada, the MXS Strada Light gives 4 fully configurable analogue inputs (max of 500Hz each) instead of the 8 that are found on the standard MXS Strada. It also doesn’t have a digital output or an RPM connection, which is found within the standard MXS Strada.
Choose either the OBDII or K-Line CAN, depending on whether you want to connect to the vehicle's ECU or OBDII port or directly to the ECU through the CAN channel.
Connecting the MXS 1.3 Strada Light dash to your ECU is simple. You can sample and display dozens of channels straight from the vehicle's ECU. This is usually the quickest and easiest setup, needing only 2 wire connections to the ECU instead of multiple connections to analogue sensors.
With the CAN output, you can send messages directly to an existing CAN network to improve the range of vehicle control possibilities. Two analogue camera inputs are also available to switch your display into a mirror camera, through a push button command or event management. The camera is sold separately.
Załaduj wideo: The MX Strada Light data and RPM on-screen as car revs.
Sample & Display Your Data
Sampled data depends on the actual ECU, but will typically include RPM, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel ratio). The list of available ECU drivers is over 1,000 and is constantly being updated and upgraded.
Display with Race Icons
The MXS 1.3 Strada Light has a compact 5" TFT high contrast colour display. The visual quality is optimised by the ambient light sensor, which keeps the backlight at the best brightness levels while on the track. Race icons allow you to apply conditions to the LED icons.
Załaduj wideo: Delta times LED display feedback on the MXS 5 inch Strada Light Display
Załaduj wideo: Integrated shift light array interface and customisable alarms for the MX Strada Light Series
Załaduj wideo: Pre-configured dash display screens for the MX Strada Light Series.
Pre-Configured Pages
The MXS 1.3 Strada Light shows the RPM scale and all the data you need, like speed, water temperature and oil pressure, lap times and much more. You can customise pages to suit your requirements, including up to four additional fields. Define what data is shown with the end of scale and measure units. Swapping between the pages is easy; just use the push buttons.
  • All channels
  • ECU drivers
  • Math channels
  • Display pages
  • Digital outputs
  • Alarms
  • Shift lights
  • Expansions
MX Strada Light Series Expansions list; SmartyCam 3 Sport, ACC3, Data Hub, GPS and more.
Turn your MX Strada Light Dash into a complete data logging system with the MX Strada Logger, Data Hub & GPS09 Module. You can also integrate an ACC3 and convert your analogue to CAN, integrating a camera and various sensors into your setup.
  • Ambient Light Sensor: Yes
  • CAN Connections: 2
  • ECU Connections: CAN or K-Line
  • Analogue Inputs: 4 fully configurable, max 500Hz each
  • EXT Video Inputs: 1 PAL-NTSC
  • Second CAN: Yes
  • Body: Anodised aluminium
  • Connectors: 1 AMP connector & 1 binder connector
  • Power Consumption: 400mA
  • Display: 5" TFT
  • Contrast: 600:1
  • Weight: 460g
SKU: MXS-S-L
MXS Strada Tech Sheet
MXS Strada Light Tech Sheet
MXS Strada Light
MXS Strada
MXG Strada Light
MXG Strada
  • 5" TFT display
  • 10 shift light RGB LEDs
  • CAN or K-Line input
  • 6 alarm RGB LEDs
  • 4 analogue inputs
  • Configure data
  • 5" TFT display
  • CAN output
  • 6 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • 7" TFT display
  • 8 alarm RGB LEDs
  • 4 analogue inputs
  • Configure data
  • 7" TFT display
  • CAN output
  • 8 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • Weight: 460g
  • Weight: 480g
  • Dimensions: 237.1 x 127.6 x 26mm
  • Weight: 850g
  • Weight: 950g
  • IP67
  • MXS Strada Light
  • 23-Pin Standard Wiring
  • MXS Strada Dash
  • 14-Pin Standard Wiring
  • MXG Strada Light
  • MXG Strada Dash
  • ECU Connection: CAN or K-Line to 1,000+ industry leading ECUs
  • Second CAN: Yes
  • Body: Anodised Aluminium
  • Connectors: 1 AMP connectors + 1 binder connector
  • Second CAN: Yes
  • Second CAN: Yes
  • Second CAN: Yes
  • Display: 5" TFT
  • Display: 5" TFT
  • Display: 7" TFT
  • Contrast: 1,000:1
  • Display: 7" TFT
  • Contrast: 1000:1
What does the MXS Strada Light do?
The Aim MXS Strada Light is a digital dash display that can be configured to show real time information from the car's ECU, analogue inputs, predefined math channels and an optional GPS Module. It provides crucial information like speed, RPM, water temperature, and oil pressure on a high-contrast TFT screen.
What size is the MXS display?
What alarms can be set on the MXS Strada Light?
The MXS Strada comes with 6 customisable RGB LEDs, which are determined by inputs from the ECU or other sensors. The MXS Strada with race icons can be configured with alarms for low fuel, high/low pressures, high/low temperatures, over-rev limits and other customised alarms that have been set.
What are the best applications for the MXS Strada Light with race icons?
The MXS Strada Light with race icons is best suited to performance driving like track day racing and compact car cockpits.
How do you display gear information on the MXS Strada Light?
Selected gear information can be sourced by gear potentiometer, ECU stream message, or it can be calculated in real time by the MXS Strada Light through speed and RPM. Each mode requires a specific gear configuration.
How do you switch between pages on the Aim MXS Strada Light?
To switch pages on the Aim MXS Strada Light, first open our free Race Studio 3 software and then select the Page Configuration to customise each page. After choosing your selections, save your configurations and press the ">>" push button on the side of the device to switch between your pages.
How do you connect & configure the SmartyCam with MXS Strada Light?
