Compact Motorsport Display
The MXG Strada with race icons is one of the most widely used dash displays on tracks around the world. The Strada ‘Light’ version has been created as a more accessible product for people who will use fewer analogue inputs and just need a CAN connection for their ECU.
The MXG Strada Light 7 inch Display integrated into a car dashboard on a racetrack
Why Choose the MXG 1.3 Strada Light Display
Whilst being very similar to the MXG Strada, the MXG Strada Light gives 4 fully configurable analogue inputs (max of 500Hz each) instead of the 8 that are found on the standard MXG Strada. It also doesn’t have a digital output or an RPM connection, which is found within the standard MXG Strada.
Choose either the OBDII or K-Line CAN, depending on whether you want to connect to the vehicle's ECU or OBDII port or directly to the ECU through the CAN channel.
Connecting the MXG 1.3 Strada Light dash to your ECU is simple. You can sample and display dozens of channels straight from the vehicle's ECU. This is usually the quickest and easiest setup, needing only 2 wire connections to the ECU instead of multiple connections to analogue sensors.
With the CAN output, you can send messages directly to an existing CAN network to improve the range of vehicle control possibilities. Two analogue camera inputs are also available to switch your display into a mirror camera, through a push button command or event management. The camera is sold separately.
Cargar video: The MX Strada Light data and RPM on-screen as car revs.
Sample & Display Your Data
Sampled data depends on the actual ECU, but will typically include RPM, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel ratio). The list of available ECU drivers is over 1,000 and is constantly being updated and upgraded.
Display with Race Icons
The MXG 1.3 Strada Light has a 7" high contrast TFT colour display. The visual quality is optimised by the ambient light sensor, which keeps the backlight at the best brightness levels. Race icons allow you to apply conditions to the LED icons.
Cargar video: Delta times LED display feedback on the MXG 7 inch Strada Light Display
Cargar video: Integrated shift light array interface and customisable alarms for the MX Strada Light Series
Cargar video: Pre-configured dash display screens for the MX Strada Light Series.
Pre-Configured Pages
The MXG 1.3 Strada Light shows the RPM scale and all the data you need, like speed, water temperature and oil pressure, lap times and much more. You can customise pages to suit your requirements, including up to four additional fields. Define what data is shown with the end of scale and measure units. Swapping between the pages is easy; just use the push buttons.
  • All channels
  • ECU drivers
  • Math channels
  • Display pages
  • Digital outputs
  • Alarms
  • Shift lights
  • Expansions
MX Strada Light Series Expansions list; SmartyCam 3 Sport, ACC3, Data Hub, GPS and more.
Turn your MX Strada Light Dash into a complete data logging system with the MX Strada Logger, Data Hub & GPS09 Module. You can also integrate an ACC3 and convert your analogue to CAN, integrating a camera and various sensors into your setup.
  • Ambient Light Sensor: Yes
  • CAN Connections: 2
  • ECU Connections: CAN or K-Line
  • External Modules: GPS Module, ACC3, LCU1S, SmartyCam 3 Series
  • Analogue Inputs: 4 fully configurable, max 500Hz each
  • EXT Video Inputs: 1 PAL-NTSC
  • Second CAN: Yes
  • Body: Anodised aluminium
  • Connectors: 1 AMP connector & 1 binder connector
  • Power Consumption: 400mA
  • Display: 7" TFT
  • Contrast: 1,000:1
  • Dimensions: 237.1 x 127.6 x 26.0mm
  • Weight: 850g
  • IP67
SKU: MXG-S-L / MXG-S-L-A
MXG Strada User Guide
Hoja técnica de luz MXG Strada
MXG Strada Light
MXG Strada
MXS Strada Light
MXS Strada
  • 7" TFT display
  • 10 shift light RGB LEDs
  • CAN or K-Line input
  • 8 alarm RGB LEDs
  • 4 analogue inputs
  • Configure data
  • 7" TFT display
  • CAN output
  • 8 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • 5" TFT display
  • 6 alarm RGB LEDs
  • 4 analogue inputs
  • Configure data
  • 5" TFT display
  • CAN output
  • 6 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • Dimensions: 237.1 x 127.6 x 26mm
  • Weight: 850g
  • Weight: 950g
  • Weight: 460g
  • Weight: 480g
  • IP67
  • MXG Strada Light
  • 23-Pin Standard Wiring
  • MXG Strada Dash
  • 14-Pin Standard Wiring
  • MXS Strada Light
  • MXS Strada Dash
  • ECU Connection: CAN or K-Line to 1,000+ industry leading ECUs
  • Second CAN: Yes
  • Second CAN: Yes
  • Body: Anodised Aluminium
  • Second CAN: Yes
  • Connectors: 1 AMP connectors + 1 binder connector
  • Second CAN: Yes
  • Display: 7" TFT
  • Contrast: 1,000:1
  • Display: 7" TFT
  • Contrast: 1000:1
  • Display: 5" TFT
  • Display: 5" TFT
What does the MXG Strada Light do?
The Aim MXG Strada Light is a digital dash display that can be configured to show real time information from the car's ECU, analogue inputs, predefined math channels and an optional GPS Module. It provides crucial information like speed, RPM, water temperature, and oil pressure on a high-contrast TFT screen.
What size is the MXG display?
What alarms can be set on the MXG Strada Light?
The MXG Strada comes with 8 customisable RGB LEDs, which are determined by inputs from the ECU or other sensors. The MXG Strada with race icons can be configured with alarms for low fuel, high/low pressures, high/low temperatures, over-rev limits and other customised alarms that have been set.
What are the best applications for the MXG Strada Light with race icons?
The MXG Strada Light with race icons is best suited to various motorsport setups, including track day cars, kit cars & competitive race cars.
How do you display gear information on the MXG Strada Light?
Selected gear information can be sourced by gear potentiometer, ECU stream message, or it can be calculated in real time by the MXG Strada Light through speed and RPM. Each mode requires a specific gear configuration.
How do you switch between pages on the Aim MXG Strada Light?
To switch pages on the Aim MXG Strada Light, first open our free Race Studio 3 software and then select the Page Configuration to customise each page. After choosing your selections, save your configurations and press the ">>" push button on the side of the device to switch between your pages.
How do you connect & configure the SmartyCam with MXG Strada Light?
