Skip to product information
1 of 1
Second-Life MXS 1.3 Strada 5" TFT Dash Display with Road Icons
SKU:
£700.00
£1,000.00
£700.00
This MXS 1.3 Strada comes back to us as a trade-in, fully equipped and ready to take on its second life. The dash is in full working order and has been meticulously checked by our technicians.
AiM MXS 1.3 Strada 5" TFT Dash Display with Road Icons
The MXS Strada with Road Icons is one of the most widely used dash displays on tracks and roads around the world.
5" compact TFT display 6 alarm RGB LEDs
CAN output Configure data
Connecting the MXS 1.3 Strada dash to your ECU is simple. You can sample and display dozens of channels straight from the vehicles ECU. This is usually the quickest and easiest setup, needing only 2 cable connections to the ECU instead of multiple connections to analogue sensors. The sampled data depends on the actual ECU, but will typically include RPM, throttle position, (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear, lambda value (air/fuel ratio). The list of available ECU drivers is 1000+ and is constantly being updated and upgraded.
Digital Outputs
With CAN Output you can send messages directly to an existing  CAN network to improve the range of vehicle control possibilities.
Pre-configured Pages
Flexible Shift Light & Alarms
Camera Inputs
Pin Harness
The MXS 1.3 Strada has a choice of ECU connection. Choose between the OBDII or K-Line CAN. Depending on whether you want to connect to the vehicles ECU using the OBDII port or directly to the ECU through the CAN channel.
  • Display : 5" TFT
  • CAN Connections: 2
  • Second CAN: Yes
  • Body: Anodized Aluminium
  • Pushbuttons: Metallic
  • Power Consumption: 400 mA
  • Dimensions: 169.4 x 4 x 97 x 23mm
  • Weight: 480g
  • MXS Strada 1.2
  • 14 Pin Standard Wiring
Digital Outputs
Camera Inputs
Pin Harness
  • Display : 5" TFT
  • Second CAN: Yes
  • Weight: 480g
  • MXS Strada 1.2
